Question about Nokia N95 Cellular Phone
N95 the top two buttons have suddenly stopped working so can not do a thing with it
  • Danielle Wood Apr 13, 2008
    The top left botton - as in the botton on top of the green answer button is not working, any ideas whats happend or how to fix it!?
    Hi, i have the same problem but its only the top left buton - as in the shiny silver button above the answer button with the green colour on it!Any ideas whats happened or how to fix it!?
Which two? The on/off button?
Posted on Apr 12, 2008
Hi good day My front camera n95 suddenly stopped working properly. Do you know of any basic way of fixing it. Thank you..
1.connect to Nokia PC suit
2.click file, select software update
3. install the update.
let me know the result.
thanks
Jul 23, 2010 | Nokia N95 Cellular Phone
Nokia N95 top left soft button is not functioning
Open the keypad pata and clean the carbon.Good luck
Jul 15, 2010 | Nokia N95 Cellular Phone
Unlock security code nokia n95 8Gb
If you have forgot your Nokia N95 8GB's security code then i will recommend you to do following:
  • Enter 00000 or 12345 as pass code first.
  • If above codes wont work then you will have to RESET your phone.Resetting your phone will end up in loss of all DATA that you have on your cell.Every thing will be restored to factory configurations no Security code will be their.
  • Soft reset code *#7370#
    Hard reset code *#7780#
    If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
    + Turn off the mobile device.
    + Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
    + While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
You shall check following link too:
NOKIA N95 Tips and Tricks
Dec 06, 2009 | Nokia N95 Cellular Phone
My blue ok button on my nokia n95 keypad suddenly not working. Top left hand side above green button.Means i cant text and add contact to send. All other buttons and functions working. How can i fix this?
This could happen often when a phone was accidentally drop or fell or there's is something being installed in the phone system that is being corrupted. To solve this kind of problem is to deep reset all the settings of the phone. It will clear or delete the files inside. Be sure to back-up all the important files in your phone like contacts. To do this just simply dial this number in your phone, *#7370# or *#7780# and it will show a message like "Restore all original settings" and phone will restart. Press okay and then enter this code 12345 which is the default. The phone will restart and reset the phone to the original settings.
Please don't forget to rate this solution..Thanks..:-)
Oct 25, 2009 | Nokia N95 Cellular Phone
Nokia n95 button not working
You need to get the button replaced.If you can open the phone then it can be done easily.But i advice you to get it done from a technician
Sep 02, 2008 | Nokia N95 Cellular Phone
N95
if your button stopped working it can be causing an extra drain on your battery via a short of some kind. Because of the sensitivity of cell phones you will probably have to replace the phone. Most likely causes for this problem are:
  • wear and tear
  • dropping the phone
  • poor battery maintenance
  • getting the phone wet or using the phone in the bathroom (seriously).
Jul 30, 2008 | Nokia N95 Cellular Phone
Nokia N95 Bluetooth
I have just spoken with 3 as I had the same problem with my Nokia N95.
The solution is:
Menu
select Tools
select Bluetooth
at top option blue tooth on - select right hand navigation button
it will say (no paired devices) select Options and select new paired device this will then seach for other blue tooth devices.
Good luck everyone
Jun 09, 2008 | Nokia N95 Cellular Phone
Nokia n95
Press the button on top of the phone for 2 seconds.
If that doesn't work, get your cheque book out and buy him a new phone.
"We are born naked, wet and hungry. Then things get worse"
Apr 04, 2008 | Nokia N95 Cellular Phone
Nokia N95 wont display Log
Resetting to factory settings will probably sort it out. But you might loose the data stored on the phone. You'll find the reset in the menu, tools, settings.
I'm assuming that you switch your phone off sometimes, if you don't, try a restart first.
Feb 11, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
