Question about Sony KP-46WT510 46" Rear Projection HDTV
Curved blue lines on screen.
I have a similar problem and wondered if the same fix would help me. I have 5-6 blue, curved lines from top to bottom of screen about 2-3 inches apart. They can only be seen when the screen is dark or in a dark scene. Otherwise you can't notice it. Should I do anything since it does not appear to be affecting the picture quality? Or is it a prelude of things to come?
  • mhuynh916 May 01, 2008
    Hi, I have the same problem except my tv is a different model. It is the Sony KP65ws700. The problem is as described "I have 5-6 blue, curved lines from top to bottom of screen about
    it does not appear to be affecting the picture quality? Or is it a prelude of things to come?" I have not tried anything. I do not know where to start. convergence problem was fixed by a tech recently. Thank you for your help.
  • 398 Answers
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Posted on Apr 12, 2008
    Problem Solver:
  • 3 Answers
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
Posted on Jul 04, 2008
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Turns on, then it goes all blue with some curved lines, then off
possible crt problem, most likely though its a convergence problem. expect to pay around $300
Jul 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Convergence
Replace both convergence IC's part# STK392-040. Also check for burnt/discolored resistors nearby.
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
Three curved lines have appeared approx. 6" up from the bottom of the screen. Is this a simple fix .... maybe as simple as replacing a bulb?
Are you saying that the whole picture is gone and all you see on the screen are 3 curved lines near the bottom, or is the picture there but 3 curved lines are over the picture, or is the picture there but the bottom of the picture has curved upeards?
Aug 23, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Descending curved line on screen
if the tv has a portal on the side open it up and make sure the screen is not out of it's track, don't set anything on top of the set it could make it happen also
Apr 13, 2007 | Samsung HCN653W 65" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
644 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
