Vista disconnects from wireless network when switching users
How do I fix this problem when switching users my vista disconnects my wireless network connnection.
  • 520 Answers
By switching user you have also switched configuration.the user that u have switched to has not been configured.it also may be disallowed.you can check and/or change this in admin.
Posted on Apr 12, 2008
Can't use my adapter...
Does the EUB-362/362EXT/862 work with Windows Vista? No, the EUB-362/362EXT/862 Client Utility was written for use with Windows 2000/XP. Microsoft Windows Vista users must use the "Connect to a Network" utility in Windows Vista.
Is the EUB-362/362EXT/862 Client Utility software supported on Microsoft Windows Vista? No, the EUB-362/362EXT/862 Client Utility was written for use with Windows 2000/XP. Microsoft Windows Vista users must use the "Connect to a Network" utility in Windows Vista.
What is your OS?
Dec 10, 2010 | EnGenius EUB-362 (EUB362 EXT) Wireless...
The msg command in vista is working for massaging locally in the network but i have the mixed os in my local network and want to use this command, whenever use this command on vista like ''c:msg computer...
first of all restart the service Messenger and in the command prompt type the command
C:\>net send recieptant's_name Text_of_msg
Eg:-
c:\>net send administrator "hello"
Mar 15, 2010 | Computers & Internet
Vista Drivers ?
Have a look on this site
and download and install
if not workimg reinstall the app in compatibility mode in vista
http://download.cnet.com/SMC-EZ-Connect-Wireless-USB-Adapter-SMC2662W/3000-2112_4-67720.html
Feb 20, 2010 | SMC EZ Connect g SMCWUSBT-G (SMCWUSBTG)...
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
I changed my password on my network. It will not make the changes on my laptop how do I fix it?
you have to manually change it on the laptop...if xp go to control panel, network connections, right click on the wireless connection and go to properties. in there there is a network tab or wireless tab i cannot recall 100% as i switched to vista. in vista right click on your network icon in the task bar and select network and sharing center, from there click on manage wireless networks on the upper left hand side double click the one you want to change and click on the security tab and change the password.
Aug 20, 2009 | Linksys Wireless-G WRT54GS Router...
Wifi disconnect on vista business
Try resetting your wireless router frm the reset button on your router....After that goto -control panel-network connections-right click on wireless connection-click on repair
May 02, 2009 | Microsoft Windows Vista Business DVD...
Wnr834b passphrase won't work
Hello jsnow4 & cooler34788,
For vista OS;
Here are some troubleshooting steps that I suggest you try:
1. Go to "Control Panel" ( switch it to classic view )
2. Click " Network & Sharing Center"
3. At the left side of " Network & Sharing Center", click Manage Wireless Connection ( under task)
4. Delete the profiles of your Wireless connections particulary the one you named for your Netgear wireless ( this is also known as SSID).
5. Click close including "network & Sharing Center"
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
Since this is an unsecured wireless, Vista will warn you if you wanna connect anyways. Go ahead and connect.
From the above configuration, please check if you can now access the Internet.
Jan 31, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Wireless network
1. check the in your pc wireless Lancard is enbled R not
2. it is not enable mean, first enble it.
3. Go to command promt, check the ip address by giving the command IPCONFIG
4. U can see the ip adress when it connected R it show media disconnected ie.Lan is disabled.
May 06, 2008 | Computers & Internet
RE:WPC300N FOR VISTA
first is it compadable with windows vista?
if so , you might just need to search for the wireless network around you and connect to it.
you have to connect to a new network where ever you go .
is there a wireless router near to where you are?
if not then you will not get signal.
Mar 05, 2008 | Linksys Wireless-N Notebook Adapter...
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
