Dirty tv screen on plasma
Ineed to know how to clean a screen on a plasma tv,
  • Anonymous Apr 15, 2008
    Problem fix
Use a very slightly damp piece of kitchen towel to wipe the screen down, and another bone dry piece to wipe the slight dampness off. You may need several pieces of dry towel for a large screen.
Posted on May 19, 2009
  • 563 Answers
Hi there
You get special cleaner for these screens from any good AV or PC shop.
Posted on Apr 15, 2008
I need Schematic diagrams of Power Supply for Tv-plasma model PD42 -Hantarex . Can You help me , Please?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 16, 2015 | Televison & Video
I used a soap/water solution to clean my plasma screen but used a regular cloth instead of microfiber and now there are horrible streaks on the tv that won't go away. Help! Is there anything I can do?
You can try to use a harsher cleaner like lysol but sometimes the streaks are permanent. The screen is glass but some tvs have a glare reduction layer that can be destroyed with harsh cleaners (like lysol). Your soap cleaning shouldn't have damaged it.. I would try just water and see if the streaks change. If they keep changing as you clean, its probably some scummy residue, but if they apprear to be permanent, then it could be damage. I always recommend the store bought plasma cleaner with the microfiber cloth, but if you smoke or have a really dirty tv, sometimes you have to cut it with lysol or something. Clean at your own risk, as anything not made to clean the tv can sometimes cause damage. I've seen paper towels scratch the glossy frames sometimes even.. good luck
Jun 11, 2010 | Panasonic Viera TH-50PX80U Plasma TV
How do you clean plasma screen
Turn off the plasma display before cleaning it. Doing this is not necessary, but it's preferred, especially if you're going to use a cleaning solution spray. Since Plasma TVs use more power than and generate more heat than LCD TVs, it is best to turn it off AND allow ample time for the unit to cool to the touch before attempting to clean the screen. Failure to do this may cause your cleaning solution to evaporate before it has had enough time to remove any dust, dirt, or contaminants on your screen.[1] Some sources suggest unplugging the TV. Use a soft, lint-free cloth to remove fingerprints and smudges. Avoid wood-based products (paper towels, toilet paper, tissues) because they can scratch the screen. If stubborn dirty spots persist, go to the next step. However, be advised that some manufacturers, such as Pioneer, recommend no liquid at all on the front of their plasmas, lest it seep into the plasma display.
If you must use a liquid, spray-- a minimal amount of--the cleaning solution on the soft cloth, not on the screen. If the moistened cloth is not cleaning sufficiently, you can spray additional SMALL amounts on the cloth. At no time do you want the cloth wet to the point where the solution drips or runs down the screen! See previous point for the reason why. Use either just distilled water or non-ammonia or alcohol-based window cleaner. Ammonia and alcohol are substances which will eventually cloud any plastic with microscopic "crazing," with the effect of hazing and dimming the displayed image. After wiping the screen gently, follow up with a dry cloth
Apr 03, 2010 | Hisense TA42P40M 42 in. Plasma Television
50 inch samsung plasma that is 3 years old occassionally gets a black bar across top half of the screen. is this tv done?
not necessarily, sometimes the connectors that feed the screen get old and dirty
If you have some electronic skills, open the TV and clean the connectors around where you see the symptoms and you may have a good chance to get if fix by doing that...
good luck
Jul 13, 2009 | Samsung PS42S5H 42 in. HD-Ready Plasma...
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Screen
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
97 people viewed this question
k24674
jasbo
jasbo
