Question about Nintendo DS Lite Console
DS LITE OK GINKO,1ST OF ALL,THANKS ALOT FOR YOUR TIME,ANOTHER THING I DIDNT SAY WAS THAT I HAD THE BOTTOM COVER OF THE DS AND I CONNECTED THE CHARGER AND JUST BEHIND THE SLOT FOR THE CHARGER I TOUCHED THE RIGHT HAND SIDE OF IT WITH MY MULTI-METER TIP AND IT FLICKED ON AND OF AGAIN AND WHEN I CROSSED TWO SOLDER POINTS UNDERNEATH IT DONE HE SAME THING,FLASHED FOR A SECOND
  • 19,396 Answers
Then is not the power charger socket, it can be the motherboard itself, a new replacement may be expensive, in this case sometimes you can find a spare parts DS on ebay.
Posted on Apr 11, 2008
I replaced the bottom screen in a friends Nintendo DS lite, because she broke it. Then the DS would only turn on for a second and then turn off, the Charger would not charge. After searching on the...
there are 2 fuses you obviously didnt insulate the bottom screen so it doesnt short out on the circuit board look at the one you took out and look at the one you put in difference is one has a backing insulation
did you blob them with solder (definatly not a good thing to do) if you did everything correctly and im wrong try this
the second thing is which every one does they never push the ribbon cable fully home (top and bottom screen) needs to seat all the way in really all the way if this helps give us a tick so to help others good luck
Aug 06, 2009 | Nintendo DS Lite Console
Nintendo ds lite won't charge just the red light to say battery is low my nintendo ds lite wont charge it always says its red
Did you attatchthe charge cord into the back of the Ds and attatch it to the wall? If you did and it didnt work, then I suggest getting it looked at, as this is usually the less expensive way of fixing it.
Mar 13, 2009 | Nintendo DS Lite Console
Nintendo ds lite charger
just buy a new one i use 3rd and 1st party work the same keep it away from your dog
Jan 15, 2009 | Nintendo DS Lite Console
Nintendo DS charger
Likely not, as the DS Phat and Lite use a special charger that you can get at Walmart or somewhere similar for cheap, although I'd complain about it to whoever you bought the DS from and see if you can get a free charger from them.
Dec 25, 2008 | Nintendo DS Lite Console
Will my razor phone charger charge a DS lite? Our new DS didnt come with a charger!
No a razor charger will not charge it.
I will ship you a new nintendo charger for the ds lite for $11
Thanks,
ninja_freak318@hotmail.com
NINTENDO DS POWER UP PROBLEM
ok its easy, 1. click the touch screen
2. click the DS icon on the bottom (in the very middle)
3.click the wrench
4.hit the globe icon
5. hit english
Jun 01, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
DS LITE.
You are welcome , if you think one of our solutions had been helpful, accept the best solution among experts voting on the main thread here. It is the way Fixya uses to reward experts, no vote no reward.
If you need further help feel free to ask us.
Many thanks
Apr 11, 2008 | Nintendo DS Lite Console
DS LITE
Ok, then is either that both chargers you used are faulty, or more likely there is a contact in the power charger socket on your nintendo. check it it is moving or not well in place, eventually you will need to chaeck the contacts of charger socket on board inside the DS, the contact must be near there. Until you do not fix it, connecting the charger may be dangerous for your DS .
Nintendo DS lite R & L button/ crack in ds
push your button up alot then blow in too it
Dec 15, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
46 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
