I have installed the HP Photosmart C7280 All-in-One and tried to print an article off the computer. I have paper loaded in the tray-I get a message Out of Paper. Load paper face down in Main Tray. What's going on?
  • 3 more comments
  • Anonymous Jun 30, 2008
    After loading paper i received a "load paper" message.
  • Anonymous Jul 25, 2008
    I have loaded paper, but I am still getting this error message.
  • steveyoshida Aug 13, 2008
    I get a "load paper" error, even with a full load of paper.  I have tried to clean the paper loading area to no avail.
  • Anonymous Oct 27, 2008
    print from computer - printer says paper not loaded.
  • Anonymous Oct 31, 2008
    I even got a spanking brand new printer, but it still has the same problems as the one I got before the RMA. Very annoying... And I hardly ever print to this printer because I also have a laser!
I experienced the same problem on a HP Photosmart C7280 All-in-one printer. The problem was that the light-blue plastic piece, which covers half of the printing paper tray, had gotten out of alignment with the gray piece which covers the other half of the paper stack. Pull the blue plastic tray out and align it properly.
Posted on Jan 13, 2009
I am trying to print a document and it keeps telling me to load paper
Hi
Turn it off and disconnect it from PC and from power.Reboot the PC.
Connect the printer again and try to print.
Look through the paper tray for any obstructions.
Feb 21, 2012 | HP Photosmart C7280 Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Not printing black
To align the printer from the control panel
1. Load letter, A4, or legal unused plain white paper into the input tray.
2. Press Setup.
The Setup menu appears.
3. Press to highlight Tools, and press OK.
The Tools menu appears.
4. Press to highlight Align Printer, and press OK.
5. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
Recycle or discard the page.
A success or failure message appears.
Note If you have colored paper loaded in the input tray when you align the printer, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or ink
cartridge.
6. Press OK to continue.
7. Recycle or discard the page.
Oct 13, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 All in One Printer. I am trying to print on new check paper, but it just keeps running it through and then prints on the regular white paper. Any quick fixes?
Check the preferences setting in your Printer Dialogue box (the pop-up that comes up when you attempt to print... the paper settings may be set to standard, which you can modify...
A quick-fix is also to simply print to plain paper, place the newly-printed form in the scanner, and press "copy" on the printer itself (the physical button, not from Windows), with the check paper loaded (place in just one sheet, as not to waste ink)
Hope this helps!
-- RT
Sep 03, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 All-in one says "out of paper".
If you get an 'out of paper' message when you do have paper loaded, this video will help. Following the steps of this video, you'll see if there's paper jammed in the printer.
Feb 25, 2009 | HP Photosmart C7280 Laser Printer
Hp photosmart c7280 won't work states calibration off
Solution
If the color or photo paper is loaded in the input tray when the printer aligns, the calibration might fail.
Follow these steps to resolve the issue.
Load unused plain white letter or A4 paper into the input tray.
Press the OK button on the control panel.
Cause
An incorrect type of paper is loaded in the input tray
May 30, 2008 | HP Office Equipment & Supplies
671 people viewed this question
jasbo
jasbo
