Need Driver: Aopen Ethernet mini Hub AOH-528
I am trying to solve some issues with my parents office network.
They have an Aopen AOH-528 Mini Hub that was installed by a tech. who has since gone out of business and who kept the driver and so forth.
At this point the computer throws out a "conflicting ISP" message when attempting to use the Hub and more than one computer - that tends to limit access to one computer being allowed to access the network or internet at a given time.
I am trying to resolve this problem (why not use it if its already here).
So, I am assuming installation of the driver on all computers using the Hub could solve the conflict issue?
Before that I need a copy of the driver - any ideas where to locate this model's driver? (Aopen site does not appear to acknowledge the existences of AOH-528)
Your help & insight is appreciated!!
Thank you.
-joshua
    Scholar:
  • 144 Answers
Hi joshua,
1.For a hub you don't need any driver.Just simply plug anything onto it.
2.I think the error message being throw by you computer was
"conflicting IP" not "conflicting ISP" .So if incase of "conflicting IP" that mean you have more than 1 computer using same IP number.So the solution is to change the IP number so that they don't get conflict.
3.make sure you use the same group of IP.like if your first computer is 192.168.0.1 then your second should be 192.168.0.2 and so on...3,.4.,5.....
Bye,takecare.
Posted on Apr 22, 2008
Ethernet 10/100/1000BT
which type problem u have like driver issue or any other specify
May 19, 2012 | Enterasys MINI-GPIC CARD W/...
Hello. I'm using Windows XP SP2 on my HP Mini
what sort of modem ??? are you using is it a usb wireless modem or an ethernet wired modem ???
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
if this driver is not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Sep 24, 2011 | HEWLETT-PACKARD Hewlett Packard HP Mini...
I need the D-Link drivers wireless network (DE-528)(0080C8)
You can download the driver from the D-Link WEB site.
http://www.dlink-intl.com/Web/product2003.nsf/fdff9a92f6c2891248256d2d00272651/00840c2d30412ac448256970002c0d13?OpenDocument
Apr 24, 2011 | D-Link DE-528 Network Adapter
Hello, i have a mini inspiron 1210 and the sound has always been very bad when i am using skype,i can't have a decent conversation or even when i am listening to music on deezer the sound is not clear at...
most likely with the speakers. try to get external speakers or headphones. if same thing happens, update or reinstall your audio driver and try different sources of sounds. if it happens only with streaming audio, most probably, your internet connection is the issue. hope it helps
Mar 26, 2011 | DELL Inspiron mini 12 1210 P/N: 312-0804...
Need drivers
This is a plug and play device in windows. You can refer the user manual which you can download here : http://driver-search.blogspot.com/2011/02/encore-enu-4usb-4-port-external-mini.html
Feb 20, 2011 | Encore ENU-4USB 4-Port External Mini USB...
When I turn on the Mini laptop, what does this mean: Realtex RTL8101E/8102E PCI-E Ethernet Controller v1.08 PXE-E61: Media Test Failure, check cable PXE -M0F: Exiting PXE ROM Operating System not...
media test failure like above while
booting means that the problem already solved as long as you can get
into Vista/win7/xp as usual. PXE shown in the massage is
the Ethernet network boot option which you’re not using. There are 4 options you can use for boot up the laptop:
1. Network
2. DVD/CD
3. USB Storage
4. HDD
That was better to use HDD unless you are connected to a LAN then you need to change it to Network
Aug 31, 2010 | Dell Inspiron Mini 10 Notebook
Aopen AOH 216 hub
Try plugging the 3 that are not connecting using cat5 and the other 3 wireless
Dec 02, 2008 | AOpen AOH-216 (90.18D10.041)
Network card
Yuo need to install a driver for your network card. Go to the IBM WEB site to download a network driver for your particular model ThinkPad.
Nov 12, 2008 | IBM ThinkPad A21m 2628 Notebook
Ethernet drivers needed
From the manufacturer's site
http://global.aopen.com/download.aspx
Choose ---- Lan Cards -- in Select a product
Choose ---- AON-325 -- in Select a model
Choose the newest driver probably R2.5 at the top
Dec 30, 2007 | AOpen AON-325D Network Adapter
Computers & Internet Logo
585 people viewed this question
David Payne
David Payne
