Question about LaCie (300728U) 250 GB Hard Drive
Computer does not recognize LaCie or give me a drive letter for it
I want to use my LaCie as an external storage device. I cannot locate it on my computer and when I try to back-up it says it can't access it.
  • 4,402 Answers
Is it a usb? have you tried another usb port?
you may need to remove the usb ports from the system and have the computer reinstall ( make sure you have the correct drivers before you do that).
Posted on Apr 11, 2008
Computer can 't recognize lacie hard drive
Does it show up in the device manager under storage or usb devices? When you plug it in do you feel the drive spin up?
How to get to device manager:
Mar 03, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My computer is not recognizing my LaCie external hardrive
First cehck whether your computer is able to recoznize other USB storage devices or not. If you see that it is not recoznizing other USB storage devices. Then you need go to your Boot Up screen, the screen that opens when you restart your PC.
Then go to the USB section and enable USB drive.
If this also does not resolve your problem, then try installing USB drivers on your PC, You can install them from the website :
I hope this resolves your problem.
Apr 20, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Computer won't recognize (Vista)
First of all make sure that the USB port that you are
using to connect it to your PC is a USB 2.0 port, and
not USB 1.0.
Also if it came with an external power, connect it to
the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is
lower than that of USB 2.0 and therefore might not
be enough to power up your USB Drive.
After making sure about this, power up your system,
and plug the harddrive, then Right-Click on my
computer icon, select manage, then go to Disk
Management Option.
On the Disk management option Page you should
see ALL the drives installed on your system,
including the hidden ones, so what you will just do is,
try and locate the one representing your harddrive,
and right click on it. then select "Change Drive letter
and Paths", and give the drive any new, unique letter
(i.e alphabet) different from the ones already on your
system, and click on OK.
This should make your harddrive to be detected
Try this out and let me know how it goes.
Hope this helps you out.
Jan 02, 2010 | LaCie d2 Extreme (300790U) 250 GB Hard...
I can find my hard drive in Device manager however cannot see or access via my computer
This is a good start:
In order to use it, you will need to have it recognized by your PC/LAPTOP and/or format it by following the steps below: (Your external drive should be automatically recognized by your Windows O/S but in some rare case, you need to tell your PC/Laptop that it has a new drive connected and what drive letter to use it :
CONTROL PANEL -> ADMISTRATIVE TOOLS -> COMPUTER MANAGEMENT -> STORAGE -> DISK MANAGEMENT -> locate your external drive -> right click on the external drive to bring up the context menu -> if required, Create required partition(s) -> if required, Quick FORMAT (NTFS is fine but I suggest FAT32 on some partition for more compatibility on drive/partition of less 32Gb) -> 'change drive letter and path' to assign a drive letter to your partition(s)/external drive(s) .
Dec 22, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lacie Hard Drive not being recognized on computer
If you are running Vista, You might be one of many people who are reporting an update that is causing some buggy behavior. Try this:
Connect the drive but do not Format the drive, right click 'my computer' then 'manage' go to 'storage/disk management' view the drives; your usb drive will not be allocated a drive letter. You can set one manually or leave it for about 2~5 minutes for one to be allocated auto. Each time you connect the drive you may have to do this.
Oct 10, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Lacie external HD problems
I would suspect your USB drivers. Go into device manager and remove (uninstall) any device under the USB heading. Reboot and see if it works better. Also I would try the drive on another computer to make sure it is working find and try a different USB cable just in case.
Jan 17, 2008 | LaCie (300770) 250 GB Hard Drive
Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Jan 09, 2008 | LaCie (300728U) 250 GB Hard Drive
HD recognized, but not accessible.
-Right-click on My Computer and select Manage. -On the left, in the Storage folder, click on Disk Management. -If the Write Signature Wizard opens, follow the wizard. -If the wizard did not open, you can right-click on the disk "Unknown" in the bottom part of the Computer Management window and select Write Signature and OK. (If the disk is not labeled as "unknown" then it has already been initialized and you can proceed with formatting). -Then proceed with formatting below. Formatting: -Now right-click on the unallocated space of the disk and select New Partition. -The New Partition Wizard will open. -Click through the wizard. You can leave most settings at their defaults, but make sure to select the option to perform a Quick Format. This will perform a quick format, that will only take a few moments (depending on the size of the drive). Once completed, your disk should be accessible with the chosen drive letter in My Computer and Explorer.
Jun 22, 2007 | LaCie (300728U) 250 GB Hard Drive
LaCie (300728U) 250 GB Hard Drive Logo
772 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
