Question about Amana ARS9266BS Side by Side Refrigerator
No cooling or water dispensing
SRD26VPSE amana: stopped cooling and stopped dispensing water at the same time. Motor is running. Is this a coincidence or not.
Look at back, lower wall inside freezer . If this is iced up, cold air may not be circulating because the evap motor behind this panel is not working. All the cold is staying in here instead of circulating to rest of fridge/freezer. Can be bad motor, bad motor connections, bad defrost clock, or bad thermostat limit switch (clipped to tubing). First shut off cooling with temp control dials,so evaporator fins thaw out. Motor may start working when turned back on. If no, then temporarily wire around the thermostadt limit switch, and see if motor runs. If yes, then thermostadt limit switch is either bad, or has'nt reached correct switch on temp. If no, maybe loose connections or bad motor.
When evaporator is cooling, but the fan is not circulating the cool air into all parts of fridge, evaporator area freezes up (colder than normal), and water line running thru this area to be cooled gets too cold, freezes, and you get no water at door dispenser.
Posted on Apr 11, 2009
La pobre maria josefa no sabe una papa de ingles, es un poco cortita y mongui........
Posted on Sep 18, 2008
    Sergeant:
  • 209 Answers
Dear mjcuevas
As a rough guess on this one, I would query the compressor/ pump that supplies the entire systtem with cold water/ air. Even though the motor is spinning up, the pump itself may be defective, and this possibly could be the case as your system is meant to be under pressure and both cooling and cold water dispensing is carried out through the pump. It may also be advisable to query the pressure regulators and any return valves in the system to ensure that these are not defective. Also check for worn or damaged piping and seals on the rear of the unit.
If this does not throw up the correct answer, then it may be advisable to go on to the internet, look up your appliance manufacturer/ vendor, and consult there FAQ (frequently asked questions) area about the product, also look at the service guide, service sheets, and any support information regarding this appliance. You can also get this information by going to http://www.google.com and searching for all of what i mentioned here, you should get a result on this, and even a guide on how to fit any new parts yourself.
I hope this information was useful, and please do let me know how you have got on with this issue.
I am also here to answer all of your questions relating any other technical issue regarding household appliances or computers/ consumer electronics, and you can talk to me anytime day or night here 365 days a year.
Yours sincerely
Oz
Posted on Apr 11, 2008
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
My amana side by side fridge quits cooling for periods of up to 4hrs, at the same time the water dispenser doesnt work.. then after 4-5hrs the fridge starts back up.. runs for probably 16hrs and quits...
The water dispenser and the compressor are separate circuits, check if the fridge has power or has no power at all during the time it is idle, test on a different power outlet.
Oct 28, 2008 | Amana Refrigerators
The freezer rale broke
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 22, 2012 | Amana ABB1927DE Bottom Freezer...
Amana side by side not cooling
What is the complete model number of your unit?
Dec 04, 2012 | Amana Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
How to troubleshoot amana refridgerator
the evap fan, fan by compressor and the compressor should all be running. if they are then more than likely a bad compressor, so junk it
Oct 30, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Ice/water dispenser not lit or working
I think this is probably just a coincidence that you changed the water filter and a couple of weeks later the dispenser doesnt work. If it failed the same or next day then possibly related but unlikely. The water filter purely affects the water supply line. Does the dispenser (water) make a noise (clicking) when activated. If it does then I would check the incoming water supply. If it makes no noise then you possibly have an electrical fault not providing power down to the water solenoid valve. The way to check the ice dispenser is to see if you first have any ice production if you do then again it could be an electrical control fault. You could check the underneath of the cabinet low level for the wiring connection from the door to see if it is dislodged or damaged however if it is a control issue then I would suggest contacting a good fridge tech. Hope this helps.
Sep 05, 2007 | Amana ACD2232HR Side by Side Refrigerator
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ARS9266BS Side by Side Refrigerator Logo
195 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
