Nintendo DS Lite Console Logo
Posted on Jun 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Nintendo DS Lite that the bottom screen went out after being dropped. Now you can hear somthing loose rattle around inside. Can this problem be fixed?
Anonymous
Level 2:
New Friend:
  • Expert 105 Answers
  • Posted on Jun 11, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
105
Questions
0
Helped
15583
Points
278
Part of your DS might be damage, the best thing to do is find a local electronics repair shop and let them have a check on it.
3helpful
3answers
My DS lite is broken, what should I do?
Usually if you can hear something rattle after being dropped, then the small square capacitor located on the motherboard right beside the power switch has probably come off. It is marked on the board L2. Simply resolder this capacitor and it should work fine. If the capacitor is broken a new on can be purchased on ebay for less than $10.00. Simply look for key words "DS Lite L2" they also have pictures on the auctions further showing you where it is located
8helpful
Power is on but my nintendo ds lite stays blank (black screen) both screens
Did your DS get a small bang?
The problem you are having is the L2 fuse located immediately below the on/off switch when you open up the DS (lower screen).
If you give the DS a very mild rattle you will here it rattling around loose inside the DS (in most cases). A lot of the time this same fuse can be soldered back into place to fix the problem all you need is a soldering iron and a triwing screwdriver (eBay).
If it is this fuse and you cant find it, you should bring it back to Nintendo for repair or your local PC repair shop should be able to help.
Bottom screen black
Your bottom lcd is busted. It'll have to be replaced.
Look online for Nintendo DS bottom lcd replacements.. Fairly cheap
2answers
DS lite was dropped and now it won't work.
They usually don't work properly after they've been dropped. Nintendo carries a 1 year warranty, they will replace it for free (but not if you've used cheat codes (Action Reply), etc). I wouldn't mention that you've dropped it when calling them.
5helpful
Nintendo ds won't turn on
Many times, it is the L2 Inductor chip that has popped off on impact- that's usually what you hear rattling around inside the housing...and it requires a TriWing screwdriver to open it. I tried re-soldering the L2 inductor back on the mainboard inside with a Hakko ESD protective soldering station, and it worked for a few days and then died again. The fix was finally desoldering another SMD inductor chip off an old PIII Socket 370 motherboard (with ChipQuik removal solder and flux kit) of very close to the same size class, from next to the Clock Generator Chip- figured it would be close to the right value, since I had no way to measure the micro- or millihenries value, and the voltage was around the value that the DS Lite runs on. The fix worked, and is still working, charging, and going strong. Usually the symptoms of the L2 inductor popping off, or failing, is being able to charge, but not being able to power up.
DS Screen
If the nintendo has dropped most probably the LCD screen will be broken. If it is broken you can replace it for around € 20.
Here you can find the instructions:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Don't forget to rate!
4helpful
2answers
Been dropped. no picture on bottom screen. lokks like a bar code. nintendo lite ds
Hmm it looks like you broke the bottom screen visuals, mainly the parts inside your DS, i guess your Ds is broken forever.
DS LITE BOTTOM SCREEN IS WHITE WITH BLUE&GRAY LINES
u need a new screen in the bottom, try to get a nintendo brand screen instead of an aftermarket.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
