Question about Nintendo DS Lite Console
DS LITE HELLO GINKO,ME AGAIN,I FORGOT TO TELL YOU THAT THE DS LITE STARTS UP ANG PLAYS WITH A CHARGED BATTERY BUT ITS JUST THE CHARGING LIGHT THAT GOES OUT WHEN I PLUG IT IN
  • 19,396 Answers
Ok, then is either that both chargers you used are faulty, or more likely there is a contact in the power charger socket on your nintendo. check it it is moving or not well in place, eventually you will need to chaeck the contacts of charger socket on board inside the DS, the contact must be near there. Until you do not fix it, connecting the charger may be dangerous for your DS .
Posted on Apr 11, 2008
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
How long should my battery last? I bought an nintendo DS lite and I forgot to ask?
Hello there, the Nintendo DS Lite has four levels of brightness. The battery will last 15-19 hours on the lowest settings, and 5-8 hours on the brightest.This can also vary depending on the type of game activity."
So the DS should last the whole time in even on the highest brightness settings, if fully charged. Nintendo states that it takes 3 hours to fully charge the DS.
hope this helped, also this site will also help you to get your ds battery to last for longer
 http://www.ehow.com/how_2015000_extend-b…
good luck
Apr 21, 2010 | Nintendo DS Lite
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
Will not charge
no you just need to go to a store and but a new DS lite battery cell, it comes with the screwdriver necessary for the battery switch
May 05, 2009 | Nintendo DS Lite Console
My DS power
How long have you had that battery in your DS? The more you use (play and charge) the battery, the battery's capacity is decreased. Try getting a new battery at,
usg.html">http://www.calcellular.com/ntd-ba-usg.html (for DS lite)
or
nds.html">http://www.calcellular.com/ntd-ba-nds.html (for DS).
Your welcome
Dec 29, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Nintendo DS Adapter
You'll need an adapter that works in your country. If once you have that it still does not work then you probably need a new battery. Without a working battery you won't be able to play the DS even if the charger is plugged in. The charging light will flash and go out if the battery is bad.
Mar 26, 2008 | Nintendo DS Lite Console
Ds power problems
mmm not exactly because if you plug the charger back in it will go orange again, so my guess would be that the ds doesnt stay charged for a long while, you can charge the ds properly when it is shut off but it does needs to be charging at least 8 to 10, you want it to last longer, play a game till the power goes just dnt save anything incase the ds shuts down while saving, otherwise it can corrupt the game and possibly the ds
Jack
Mar 12, 2008 | Nintendo DS Lite Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Ds lite
You never want to play the DS while it's charging, if constsntly persisted it can cause a form of battery leak.
IMPORTANT: Don't charge the DS until it dies on you completely!
When charging the DS the system will display a red light to show it's at its lowest energy, the time it takes to fully charge a DS can take up to 2-3 hours. In the second hour of charging the light will appear green but you don't want to disturb it until the light goes off. ( showing it's energy is full )
Nov 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
82 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
