Question about Kenmore Elite 45986 Front Load Washer
Kenmore he3t I already did that, I guess I should have said that, one thing I did not mention was that the pump started making a buzzing rattleting sound, so any more suggestions. Thanks.
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like a bad pump assy, sounds as if htepump is "locked up" and not moving any water at all
Posted on Apr 12, 2008
HE3t leaves water in drum after the wash cycle is complete. Already checked the drain clean out...still leaves water in the drum.
Since we are working on the drain side of things only 2 things can happen to not get the water out of your tub-1 the pump isn't working,something stuck in it- 2 you have blockage which we know is not in the trap-check conection to the tub and the pump and all discharge hoses-cheers Denny
Oct 15, 2013 | Kenmore HE3T Washer
When starting the wash cycle, after 1-2 is shows HF.
do you mean f/h ,no water to unit ,,,check to make sure hot and cold taps are on both...check for kinked fill hoses ,,if theres water in unit already check,pump..it will not fill with water in unit,,make sure theres no leaks from hose anywhere,,,good luck, repost if moe help is needed
Sep 11, 2011 | Kenmore HE3T Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Sep 17, 2009 | Washing Machines
Kenmore elite washing machine spin cycle slow. The clothes are still dripping wet when removed from the washer.
In my HE3T, this was indicative of the water pump going out. In its 8th year, my HE3T is now on its 3rd water pump.
Aug 02, 2009 | Kenmore Washing Machines
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My kenmore elite he3t showed an error code f02, i unpluged it and plugged in back in i tried to run a drain/ spin and the machine make a strange noise i suspect the motor filter is clogged and the moter is...
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
***You stated that there was a noise when you started a manual drain. This may be a damaged drain impeller. in this case, replace the entire pump(drain).
Kenmore Elite 45986 Front Load Washer Logo
95 people viewed this question
Sal De
fordexpert
Robert Rankin
