Performa washer i can run the first load ok but when i put second in it only operates part way through the cycle and quits. When it quits nothing will work no matter what position i turn the timer to. After it sits for a while it will come back on by it self. I replaced the timer and still have this problem.Its like the motor is getting to hot and has to cool down.
    Genius:
  • 1,073 Answers
Motor is over heating and cycling of on the internal overload of the motor, its motor time
Posted on Apr 11, 2008
Why does this happen sometimes and not always
YOUR CODE 01 - LOOK CLOSER I THINK IT IS C1. MOTOR PROBLEM - DRAWING TOO MUCH CURRENT. MUST FIND OUT WHY MOTOR WORKING TOO HARD. TOO HEAVE LOAD BUT U SAID DID NOT MATTER. ROTATE DRUM BY HAND AND NOTE IF IT IS SPINNING FREELY. IF OK REPLACE MOTOR.
Feb 17, 2015 | Whirlpool WTW6400SW Cabrio Washer
Maytag bravos mvwx600xw0
It is possible that poor water flow may be the culprit. Most washers operate on a water level system. The water levels have to be reached before the next cycle begins . If the water flow is slow this can extend the run time. To remedy this shut water off to unit disconnect hoses at unit. There usually are screens inside each hose connection on washer gently remove these and clean them.reinstall in washer. Before reattaching hoses put the unattached ends in a pail and turn the water on to flush out the hoses. Then reattach them and see if this solves the problem. Hope this helps.
Dec 31, 2013 | Washing Machines
When I start a cycle it starts to fill for a second and then stops.
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 23, 2012 | Frigidaire GLTF2940ES Front Load Washer
My dishwasher makes a loud noise during wash cycle. quiet during filling and draining.
Could be a matter of how much is loaded in the racks and how it is placed. Something that is loosely loaded or located where the spray from the wash arm hits it can make quite a racket
Sep 17, 2012 | Frigidaire Dishwashers
Aqua smart has power won't start cycle
hi, first thing i would check is the door is locked properley if ok then check filter if has 1 if this ok then check drain hose at the back of the washer make sure it's not blocked hope it helps
regards
shaun
Nov 18, 2011 | Fisher and Paykel Aquasmart wl80t65c
Kenmore Oasis HE quit during cycle
tell them you want another one.  It sounds like a bad start up capacitor on the motor.  Nothing you can do but wait and boil.
Apr 01, 2009 | Kenmore Oasis HE 27062 Top Load Washer
Washer starts, runs a few seconds and stops,does it over and over
Sound like the internal overload on the motor may be going out .Thsi is usuaklly due to bad or worn bearings. If you know anything abotu electricity,take a voltage reading at the motor whe it is in the run cycle(when it stops) If you stil have have the 110Volts to the motor then the motor is bad and need to be replaced.If you do not then you wil have to look elsewhere for the problem.
Dec 14, 2008 | Amana NAV5800A Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Hotpoint Aquarius WD645
If you by accident press the start button and the cancel button at the same time it puts the washer into demo mode.To switch it off press both buttons at the same time and hold until dEND is displayed. Sometimes you have to keep trying but it will work, it did with mine ok.
Sep 09, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Washing Machines Experts
