Question about Brother FAX-575 Plain Paper Thermal
LCD is blank
My machine is an Intellifan-620. Thermal roll paper. The phone part works, but the LCD is blank no printing, etc. Does this mean the machine has gone to the graveyard? I have had the machine a looooooong time. Thanks. maglbfw
  • maglbfw May 22, 2008
    Thanks for the input. I'll add it to the "pile".
  • Brother Master
  • 5,568 Answers
Uh-huh, you have had it for a while; I repaired these in my former shop that I closed in 1999.
The failure is almost certainly due to the expiration of a cheap component called a capacitor located in the power supply.
The problem was these were TOO cheap and are subjected to a kind of service they do not like.
They kind of fade away unnoticed but finally lose so much of their original capacitance they can no longer do their job.
If you were 'down the road' from me, I would do a freebie on that one, I know it well.
With the price of a new machine (albeit an ink jet that costs MUCH more to feed) so low now, I suggest adding it to the pile of 'things not worth repairing any more.'
Posted on May 21, 2008
I change the paper and now it wont print what do i do?
samer650 requires 2 1\4 thermal paper to work. make sure the paper you are using is thermal...also it is only thermal coated on one side so try it upside down if it still won't work.
Phil
Jul 10, 2014 | Samsung SAM4s ER-650 Cash Register
Want to know how to load thermal paper on my sharp Fax model FO-71
1 - Grasp the finger hold and pull up to open the operation panel.
2 - Flip up the front paper guide.
3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
4 - Unwrap the roll of thermal paper and insert the paper shaft.
5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
• Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
come out blank after printing.)
6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
7 - Make sure the paper comes out straight, and then flip down the paper guide.
8 - Close the operation panel, making sure it clicks into place.
• FO-71: A short length of the paper will be cut off.
Dec 01, 2010 | Office Equipment & Supplies
Blank paper coming out
Could paper be upside down? The rolls may be wound wrong. Thermal paper only is sensitive one side. Rolls might be defective.
Apr 26, 2010 | Sony UP DR100 Thermal Photo Printer
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Dec 09, 2008 | Office Equipment & Supplies
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Panasonic KX-FPG376 Plain... Problem:
Thermal paper roll upside down. You can only print on 1 side of thermal paper. also could be the thermal head in which case not worth repairing. Lawrence
Mar 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
Feb 15, 2008 | Brother IntelliFAX 885MC Plain Paper...
Fax machine
Really? A thermal roll fax? Not working? I don't mean for this to sound brash, but in all sincerity, a nice plain paper basic fax can be had at almost any retail outlet (Wal-Mart, Staples, etc...) for about $60/$70 these days. Why even try to fix an antiquated piece of equipment like that?
Oct 11, 2007 | Sharp UX 108 Roll paper Thermal Fax
Brother FAX-575 Plain Paper Thermal Logo
53 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
