Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I leave Michigan for the entire winter and there is no heat in the house, will below freezing weather hurt my lcd tv. Also can i store the tv in a flat position.
  • 472 Answers
If you mean flat so you can slide it under a bed for example so it's not visible to someone looking through the windows, then that is fine. The easiest way to do it is lay a blanket on the floor, lay the TV onto the blanket on its back and put another blanket over the screen to help keep dust off it, then slide the whole thing under the bed.
The below freezing I cannot comment on, I live in Australia were cold means anything thats not over 30 degreess celcius =)
Posted on Apr 11, 2008
Is it okay to store a window air conditioner outside in the garage all winter in New England?
in freezing weather oil will thicken, but if you wait for warm weather to start up you would be ok
Oct 10, 2015 | General Electric Heating & Cooling
How do you winterize a hot tub? QCA Jewel Model SUV M7
this is taken right from a jewel series QCA hot tub manual.....Winterizing
In very cold weather you may not want to venture outside to use your spa. In this case, you may move it to a heated area, or leave it as is until the weather warms. If you do leave the spa unused for a long period of time in severely cold weather, you should winterize the spa to avoid accidental freezing due to a power or equipment failure.. Follow these easy steps: Turn power to the spa OFF. Drain the spa. Use a wet vac to **** or blow out the air injectors, water jets and water suction fittings. Add 1-3 gallons of RV antifreeze, depending on the size of the spa, to all the air injectors, water jets, suction drains, and filter. Caution: Any lines not receiving adequate antifreeze are subject to freeze damage!
Dec 29, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have a Frigidaire refrigerato with top freezer that I keep on the back porch. The freezer has quit working completely. The temperature has been below freezing lately and I was wondering in this has...
Good day,
Yes, Frigidaire specifically states any temperature below 55 degrees will unbalance the machine causing the freezer to warm.
This is due to the fact that the thermostat that runs the entire machine is located in the fresh food section. When it reaches it's normal temperature it shuts the entire machine down.
In cold weather it could stay off for the best part of the dy, if not the entire day.
As well. on some model Frigidaire's, they makes a winterizing kit.
It is wired to the thermostat in a manner that heats the thermostat artificially in cold weather to cause it to cycle more.
Contact your local appliance parts house to see if they carry the kit for your machine.
Feb 17, 2010 | Frigidaire FRT21H8 Top Freezer...
Can the tv be left in cold weather
The issue is not so much the temperature, but the moisture present in the air. When these sets are manufactured and transported all over the country, they sometimes are in freezing temperatures without problems. Taking a set from a cold environmetn (shed for example) and bringing it into a warm house would not be good. The cold TV would "sweat" as the humidity in the air condensed on the boards and components. This could cause potential problems. In short, as long as you give the set time to acclimate to the room, it should be fine.
Dan
Oct 19, 2009 | Apex Digital AT2002S 20" TV
Flat screen tv winter storage
HELLO
Your TV will be fine as long as it is kept at room temperature indoors and not inside a shed or similar outbuilding. Much warmer in a house, probably near freezing in a wooden shed.
Hope this helps you (:-)
Oct 17, 2009 | RCA L32HD31 32 in. LCD HDTV
Closing down my summer home for the winter. will my vizio lcd tv freeze if i leave it in a unheated house?
no but it may not be there in the spring
they are easy to steel but any way just unplug it and it will be fine.. in the spring it might be dime when you first turn it on floresant tube will do that when they are cold
Sep 28, 2009 | Vizio GV42L 42 in. LCD Television
LCD tv
Do lcd tv freeze in cold weather. I keep mine in my garage and heated in the day but not at night
Nov 11, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
197 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
