Question about SanDisk Sansa e250 MP3 Player
Stopped playing I received a shock when I touched a door knob.(not from the MP3 player)Like the kind you get from rubbing your feet on a rug then touch someone. I reached for the door with my right hand and had my left hand in the pocket. my sansa e250 shut down immediatly and I can not get it to turn on. Please Advise
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Samsung YP-Z5 has locked up while playing. Cannot exit, or change, or shut it down
This is the same problem I have! Try cleaning the resistive touch-pad (located under the sticker in the center) and the ribbon wire connecting it (green and flat with 4 strips of metal in it) with a bit of Windex or rubbing alcohol. The pad has various wires of different resistances in it and when certain groups are connected (touched) their resistance combines. For this to actually work, the pad has to be super clean and free of any corrosion.
This picture shows the buttons and the ribbon wire:
The pad is under the sticker with the arrows on it:
Jun 21, 2012 | Samsung YP-Z5 MP3 Player
Tip
Ipod Touch vs. V -Touch
I would go for the ipod touch. Although it cost about $150 more than the V-Touch it last longer. For example first two days of owning my V-Touch the screen stopped working and it wouldn't turn on.My son brought his to school and when he got home there was a huge dent in the back plastic. Also they are very iffy a lot of videos won't work on V-touches and music and images. Although for the ipod touch you will be using itunes a lot adding more expenses they are more durable and rugged and have way better screen quality and sound quality. But if you are going for a gift for a younger kid ages 7-9 the V-Touch is exactly what you're looking for, a fun media player that won't last for ever but will last until you buy a more advanced (higher priced) media player. So if you are looking for something that will last for a a year and a half go for the V-Touch if you are looking for a long time commitment go for the ipod Touch.
on Jan 03, 2010 | Audio Players & Recorders
I cant hook up my mp3 player up to my kenwood cd player!!! i bought the hook up too and i still cant
select the auxillary input display and push the control knob left or right until you see portable, then you should be able to play your mp3 device
Mar 28, 2011 | Kenwood KDC-MP235 CD Player
Hello, towards the harmattan period of 2010,i noticed that my car was shocking me,if i hold any metal object on my hand i.e like a bunch of keys and it contacts with the door, it was so amazing until a...
This is called static build up, its due to acrylic clothes and other materials you might wear rubbing up and down on the seat ,when you exit you usually go to hold the door after your feet are on the ground and any static build up is then grounded through your hand to the floor to stop this go to a local car dealer parts dealer and purchase an anti static strap which are cheap and ask a would be mechanic to fit it takes abot 15 minutes time, this will solve you static problem
Feb 28, 2011 | 2003 Ford Escape
How do i know if my humidifier is working? it doesnt produce the white mist
Check your humidistat and it should click close to what you have it set on. Also if your humidifier is not working you can rub your sock feet on the carpet and touch a door knob and get a little shock.
Jan 05, 2010 | Holmes Products Humidifiers
My sansa express radio stopped working. The other music still plays.
which sansa model do you use?
one having radio + mp3 play feature?
so mp3 playin' works but the radio-receiver seems to be broken? please give some more details and come back.
Jun 17, 2009 | SanDisk Audio Players & Recorders
Squeaky noise when open door
petroleum jelly rubbed on the nylon cord and all parts that it touches...it does the trick
Jul 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Static electricity
everything works but no volume comes out the dock or the head phone plug??
if it's the head phone plug you could have burnt something out in between well i guess that would be true either way
if it is the head phone plug there is a good likely hood you can get away with minor wallet skimming
if it's both then you got me and if it's the dock then just be happy it's not totally blown
Mar 25, 2008 | Apple iPod MA446LL/A MP3 Player
MP3 Player
if your player stopped responding like downloading the music from your computer to your player or after your player is not working just reset by using paper clip to the hole and press down until your player is off then press on it should work properly sometimes it does freeze or crashed at some point.
Feb 23, 2008 | iRiver H320 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
