Question about Acer TravelMate C110 Tablet PC
Hello i hv a acer travelmate c110tci and i hv a problem with it!
I hv buyed a acer c110tci recently few days ago and i want to buy a external dvd writer for it like sony,samsung or others should it works on it or not coz i don't know wht type of usb is in it and the external dvd writer requires 2.0 usb and my windows is also corrupt i want to install a vista so i want to buy a external drive if i boot with external dvd writer should it boot or need a driver plzz help me?
Your Acerf C110TCI will not succesfully run Vista. It does not meat the minimum requierments. It may load, but you won't like it. Stay with XP and SP3, it will be much better.
Thanks
Brian
Posted on May 31, 2008
I am looking for travelmate c110 keynoard to replace the current keyboard.
http://www.cdsparts.com/p-37-new-acer-travelmate-c110-series-keyboard-kbt2707001.aspx
This is a place to buy a new one. Let me know if you need any more help. Hope this helps.
Mar 07, 2011 | Acer TravelMate C110 Tablet PC
Can't get the wireless button to work CT110 Acer TravelMate
Sometimes the program "Acer ePM" (Power Management) takes priority. Check it at "Start" "All Programs"
Dec 29, 2009 | Acer TravelMate C110Tci Tablet PC
How to break bios password
Continue with a blank password field, since none was manually set.
If that doesn't work, locate the BIOS battery and remove it for several minutes and replace it, that should flash the BIOS to default.
Feb 12, 2009 | Acer TravelMate C110Tci Tablet PC
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
DVD WRITER
What kind of plug in are you using to hook to you computer a Usb, If so go into your device manager and look into the usb settings when the dvd is plugged in and turned on, Now find the device you plugged in you should see it in the under the usb tab and open the plus + sign then make sure you are online and try to update there see what happens, If that don't work go into your control panel and go to the add and remove hardware and use that to install drivers for the dvd writer it should install them there If not let me know we will fix it somehow if that don't work, Thanks for reading my solution and Have a Happy Holidays
Dec 15, 2007 | Acer TravelMate C110 Tablet PC
Buy replacement keyboard for a Acer travelmate C300 tabletpc
Ebay is a good place to start. To replace it. Take out the screw on the back labeled "KB." Then on the front, there are three tabs on top of the keyboard (closest to the screen). Take a pen and pull them towards you. Then take the keyboard out and put the other one in.
Aug 26, 2007 | Acer TravelMate 302XCi Tablet PC
Pen problem: need to push extremely hard
You should buy a new tablet pen from acer's website and see if that works that is the cheap fix if it works
May 29, 2007 | Acer TravelMate C302XMi Tablet PC
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Feb 08, 2007 | Acer TravelMate C112TCi-SP2 Tablet PC
Sudden death
try check memory maybe its corrupt or try with other memory and on laptop.check error,
Jun 16, 2017 | Acer TravelMate C110Tci Tablet PC
Acer TravelMate C110 Tablet PC Logo
149 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
