Question about Intel Motherboard
I have asus motherbaord PTGD1-LA
When I try to start the PC, only Powersupplies fan rotates and can also hear the hard drive noise. But motherboard doesn't boots up. I changed the powersupply same result. Is it possible to repair motherboard. I am electonics engineer and can understand if you guys give me any tips.
  • 4 more comments
  • CharlieA63 Jun 07, 2008
    I have the same problem with the same motherboard as well. Did you find a resolution to this problem?
  • manflecha Sep 10, 2008
    I already check that all power plugs are correctly fastened. I will plug another video board in order to check if I can see at least BIOS settings. Keyboard also appears not to be working.
  • slsmls2008 Dec 08, 2008
    I HAVE HTE EXACT SAME ISSUE, DID YOU EVER FIND A SOLUTION TO THE PROBLEM???????
  • Anonymous Jan 27, 2009
    Power supply fan spins, hard drives spin up, no beeps, no cpu fan or main board fans. It's like a voltage rail is down but it seems it's probably the main board, not the power supply. I've tried new and old power supplies and no luck, but they work on other computers.
    2 days after this problem started it actually worked again for 8 hours, but it wouldn't restart after I shut it down.
  • Anonymous Jan 31, 2009
    How can i get ASUS PTGD1-LA VGA Driver
  • odie63342 Mar 09, 2009
    Could anyone suggest a motherboard replacement that will accomodate the existing components of my hp pavilion a1221n?
    I need to upgrade for as little cash as possible.
    My specs are here:
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    any help is very appreciated.
I want compaq ptgd1-la motherboard drivers
Posted on Jan 12, 2009
  • 57 Answers
It don't matter if you are engineer the best thing you check is your hard drive electronic parts sometimes it trigger the motherboard not to start replace the hard drive with the one you know it works pls inform me if this solution it help
Posted on Oct 11, 2008
    Sergeant:
  • 221 Answers
How long have you been experiencing this problem? Are you sure your hard drive has not been formated? Check inside the case to make sure all power plugs are fastened securely to the motherboard and peripherals.
Posted on Apr 11, 2008
  • 3 Answers
Check your Capacitors the tops may be swallon and defective. Big problem.
Posted on Feb 05, 2009
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
I need a cooling fan for my motherboard which is a ptgd1-la. it is the 4 pin type which is screwed into place as opposed to the clip on type
Shop for a Socket 775 CPU heatsink with fan. Many to choose from. Just watch the physical size. That it does not extend out drastically and hit other components.
GL
Oct 11, 2012 | ASUS PTGD1-LA Motherboard
Clock gen. ptgd1-la - what is #?
Clock gen. depending how it is used int he sentence or paragraph can mean the clock generating chip, or portion of a multifunction chip.
It can also mean your clock speed, such as the 800Mhz buss speed that board is capable of. If there are jumpers by it, if it is on the board- you have to manually set the buss speed, or the manual setting will take precedence over the bios/system selected buss speed. This would be for the speed you choose for the memory sticks primarily
It can also refer to the source of the clocking reference if you wanted to try overclock your processer for greater computing speeds than the factory designated speed.
Feb 07, 2012 | ASUS PTGD1-LA Motherboard
Looking for motherboard driver asus ptgd-la
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 14, 2011 | ASUS PTGD1-LA Motherboard
My HP Media Center PC M1170n with a asus ptgd1-la motherboard runs but will not boot. The fan runs, both CD and DVD drives attempt to read(lights flash for several seconds each) but even using the HP...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
if this fail to fix the problem
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 17, 2011 | ASUS PTGD1-LA Motherboard
I have the ASUS PTGD1-LA Motherboard, anyways, i recently took out all the components inclucing the motherboard, to look at the bottom side looking for the id number..Anyways, I put everything back...
Hi there , THis sounds like a CPU issue...Make sure you correctly put the CPU fan , and heatsink back on .... otherwise your CPU will overheat and cause your PC to turn off , so that it wont damage your CPU.Try making sure those are correct.
Thanks
May 22, 2010 | ASUS PTGD1-LA Motherboard
How should I upgrade my BIOS pls
The first uestion to ask yourself is "Do I need to upgrade my BIOS?"
If you are not conversant with doing so then you could rendr your PC irrepairable.
The BIOS is the heart of the motherboard and has nothing to do with system issues and should not be taken on by novice computer users.
If everything is running OK don't try and fix it.If not state the problem, it will probablely have nothing to o with the BIOS
Oct 03, 2009 | ASUS PTGD1-LA Motherboard
Need ASUS BIOS to control fan speed
This program might help you
http://uk.geocities.com/twistedfuryuk/fanspeed/
It lets you monitor your system's temperature in windows as well as controling your fan's speed
Feb 20, 2008 | Computers & Internet
Intel Motherboard Logo
1,650 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
