Power Button Blinks 3 times and then nothing happens
On of the parts on the blue light board had a shock due to the screen leaking, i manage to find a tech gut who can seal the tube, but the problem now is that he is telling me that i have to replace the chip board (where the DVI Chip is and where you connect the signal cables). Does this make sense?, the sympthom is that the power light blinks 3 times and nothing hapens, he says the flyback transformer is working cus he can check the pulse on the chip and it gets ok, but the chip is not sending any pulse outside.
Is this a flyback transformer problem?
Or is he lying so i can buy the board?
  • 2 more comments
  • rodmorf Apr 11, 2008
    The TV is a RCA model D61W20. The chip board when i open it was clean, did not had any traces of fluid, i did this right after the electric shock happend.
    Hi, thanks for your help, the blinks are like this
    I Push the power button and then...
    BLINK, 1 second pause, BLINK, 1 second pause, BLINK, and then nothing, the light is off and does not come back.
    I have to wait like 30 seconds to push the power button again so it can give me the same thing.
    Thanks for your help.
    P.S. is there any web site where i can find the error codes blinks?
  • rodmorf Apr 16, 2008
    Hello, ive replaced the mainboard and seal all the leaks on my TV, everything is working fine, except that i cant manage to fix the convergence on my TV, any body knows where i can get a COnvergence diagaram to tune up my screen?
  • Robert Johnson May 11, 2010
    what is the brand and model?
    Sergeant:
  • 395 Answers
Code 33 is convergance amps. code 33 is 3 flash then 3 more long pause then repeat. is this what is happening? the convergance amp is the whole board.
Posted on Apr 11, 2008
  • Robert Johnson Apr 11, 2008
    ok, that is not a error code. error codes repeat over and over. without being in the set I can't tell you if you need the SSB board or not. if you had fluid damage from the crt's it may be shorting some other place of the system. more than likely the large signal board is to blame. Horz. pulses can still be present and the flyback or the Horz output transistor could be at fault. then again any short can cause this no start condition. the coolant can short the crt board and get in the crt socket so remove it and clean it. clean the plastic pin hoder on the crt, becareful not to bend the pins (donot try to remove the plastic from the crt damage to the crt can happen).
  • 2,322 Answers
If the coolant spilled on a circuit board, there are changes that the board might be damage as this liquid is highly corrosive and also can conducts electricity while on the board.
What is the brand and model of the TV?
New to this site! Hope someone has an answer that can help... I have a LG 55 LCD flat screen model 55LD520-UA. Try to turn it on. Bottom light blinks red 3 times blinks blue once, then nothing.
Try to change the capacitors first. Normally lost of lcd tv have problems with the capacitors and which lead to powers problems. May you will not find visually that the capacitor is fault. So go for changing the capacitor also check the following video. Which will help you understand how to check the power supply broad. Also take care while working with the power board there is a risk or electric shock Also one of the capacitor in the power supply holds charge even when you have remove the power supply.
Testing LCD TV Power Supply BoardsSTEP BY STEP
www.electro-medical.blogspot.com
Oct 30, 2015 | LG Televison & Video
Won't power on
You still have power supply trouble, even after replacement of the board. Recheck the replacement work; could be something wrong there
Jul 19, 2013 | Philips 47PFL7422D/37 Television
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
RCA TV RCA D61W20, Light Blinks 3 Times
Usually when the crt leaks onto the chassis it can be cleaned and the affected components only have to be replaced I am not sure what "chip" you are refering too, but most ICs can be purchased as a replacement part. usually the entire board wont need replacing unless the traces are destroyed or replacement parts are unavailable.
Apr 11, 2008 | Televison & Video
Televison & Video Logo
261 people viewed this question
Top Televison & Video Experts
Electro Med Services...
