Question about HP Creative Sound Blaster Audigy 5.1
Please help i jammed the jack to my sound card, heard a loud screeching sound and after received a message saying that i need to install drivers for my hardware - multimedia audio controller. the sound card is creative one and has these numbers on it. sg0088gf-1272/-1c4-1d77. unable to hear any sound
  • ayanaalexis Apr 11, 2008
    thanx a million. i couldnt believe it was as simple as changing the slot.
  • 472 Answers
Shutdown the computer and remove the power cord from the power supply.
Remove the card and check it for any physical damage. Something may have shorted out when you "jammed the jack" into it.
If there is nothing obviously wrong with the card, then reinsert it back into the slot fully, put the holding screw back in place and boot the computer back up.
It should find the drivers automatically (since it was previously installed)
If it dosn't, then shutdown again, move the card to another spare PCI slot and tray again.
Failing that, goto Creatives website. There is an option in the support section to allow Creatives webpage to scan your computer for drivers that you need automatically.
Hope that helps.
Posted on Apr 11, 2008
  • Peter Thompson
    Peter Thompson Apr 12, 2008
    Sometimes it's the smallest thing that makes something work =)
    Glad to help =)
Whirlpool cabrio started making a loud noise when spinning. I've replaced the suspension springs before. Is that all I need to order? It's been a while.
Sounds like the bearings are toast. These machines have a poor seal in the tub which allows water to penetrate the bearings, drying/rusting them out. Go on "youtube" and search your problem. I use a 2"X4" and a jack on the center shaft to lift the drum out. Bearing tool and shaft/bearing, seal kit is approx. $150. Should take you approx. 4 hrs. if you're handy.
Nov 28, 2016 | Whirlpool Washing Machines
I do not have the software on my computer to install the speakers. where do i find it online?
No software is required for (any) speakers!
Just connect the speakers to the outlet and to the GREEN jack on the sound card...
If no sound is heard, make sure the sound card driver is properly installed and the sound is not muted.
Regards,
Pelu.
Feb 18, 2011 | Juster AC-691 Computer Speakers
Creative sound card! no sound!
Check whether you plugged in the speaker wire into the correct jack at the back of the computer (it should go into the green colored jack on the sound card).
Did you try playing a sound file? Does media player show the file as playing, but you can't hear anything? Or do you get any error? if there's any error, please mention the error.
If the sound plays but you can't hear anything, again, check the speakers are connected to the correct sound jack. Next, try connecting a pair of headphones or earphones (lower the volume before playing any sound  or music file).
If you still can't hear anything, click Start and type the command "dxdiag" in the Run box and then press the Enter key. In the dxdiag window, click the Sound tab. Check the Notes box, if it gives any error info. If your card is working, it should say 'No problems found." You can also test the sound using the "Test Directsound" button.
If you still can't hear any sound, you should check and reinstall your sound card driver manually after removing it first.
There may be other problems. For more information, check this nice blog post about sound problems.
Hope that helps.
Regards,
Raspal
Jun 14, 2010 | Creative Labs SB0400 Audigy 2 Value Var...
What happens when it says "No audio output device installed." I have no sound. Please respond
Hello! kindly follow this steps below:
Please find your motherboard or sound card driver then insert it in your disk in the CD/DVD ROM if it is in a disk then run the setup.exe of that driver software then follow certain steps given by the computer installation wizard. Then after you finished the installation restart your computer then if the sound is restored then you have a successful sound card installation. You can do this steps again if you encounter same problem next time. The reason why this you receive this error message cause your sound driver has been corrupt and need to reinstall due to some hardware failure and software failure especially if their are virus and worms enter in your system.
Also try to update and install anti virus and update it in order to proctect and level up your security against virus, worms and hackers.
If you need more assitance please reply to this post.
thank you
Jul 17, 2009 | Microsoft Windows Vista Ultimate Edition
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
Digital answering machine
Hi Bibi - Is this a regular land line? Is the fax machine supposed to answer if it's a fax but not answer if it's a phone call? Let me know exactly what your mothers' setup is please. It sounds to me like the fax is trying to answer all the calls and the screeching she hears is the fax machine try to handshake, or connect, with another fax machine. You've probably heard what that sounds like. Let me know the answers and if you can ask some people that called if they heard anything. Thanks.
Jeff
Jul 19, 2008 | Radio Shack 3808 Digital Answering Machine
Sound problems
Sound Recorder Help When trying to play a sound .wav file you receive the following error message: "Sound Recorder cannot record or play back because a sound device is not .
Computer Sound Card Help Line Out connector is the location which the speakers or headphones will be connected to get sound out of the sound card.
Good Luck, Please dont for get to Vote/Thank You.
Dec 21, 2007 | Toshiba Satellite A60 Notebook
HP Creative Sound Blaster Audigy 5.1 Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
