Question about Linksys Wireless-G WRT54G Router
Linksys wireless-G 2.4 GHz broadband Router
Hi, You suggested I put into my browser and then log-in. I can't get a log-in page. Only other suggested sights. Any suggestions?
  • 2 more comments
  • Anonymous Apr 18, 2008
    durant l'installation avec disque le mot de passe est refusé
    mot de passe refusé avec cd d'installation. Tenter de résoudre j'ai mis plusieur heures
  • jean-michel Apr 18, 2008
    mot de passe refusé durant l'installation avec cd.Chercher des autres mot de passe.
  • cbegley3 Nov 27, 2008
    i have lost my cd and nees to download linskys to my new laptop
  • 1,027 Answers
If the default ip address has been changed, reset the unit. Reset is on the back small button or pin hole. Plug the cat5 cable into the router and your network card on your pc, then log back in using default no user name, password is admin.
Link to linksys troubleshooting wizard.
Posted on Apr 17, 2008
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router Wireless G-Broadband Router support b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router
Mar 27, 2013 | Linksys Wireless-G Broadband Router
How to set up The wireless G 2.4 GHz broadband router linksys?
Plug a computer into the router. Open your web browser and in the address bar type or If the router is fresh from the factory the login will be admin and the password will be password This should get you into the configuration for the router.. from there look on the left side of the web page and you will find config options for all aspects of the router.
Apr 14, 2011 | Linksys Wireless-G Broadband Router
I have an unsecured router ,linksys wireless-g 2.4 ghz broadband router,need password and username to secure it.
There is no need to ask for a username or password. Just log in the settings' page for your Linksys with your browser (typically it's, provide the username and password to connect with the router and make the settings you like for the Wi-Fi name at WLAN SSID section and the password you like at the security section. At the end hit apply (or save). I advice you to make all these settings while you are connected with an ethernet cable at your Linksys, to avoid being locked out in case of a problem.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Nov 09, 2010 | Linksys Wireless-G Broadband Router
Wont send signal
Please check your router's setting area and must be your router on mixed mode.
Apr 13, 2010 | Linksys Wireless-G Broadband Router
I have a linksys Wireles-G broadband router 2.4 GHz that i am trying to hook up to a desktop to allow wireless access for a laptop and I cannot get it to log onto the internet. Why?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 21, 2010 | Linksys Wireless-G Broadband Router
Linksys Wireless-G2.4 GHz Broadband that my laptop doesnn't recog
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
If that doesn't work then upgrade the firmware of the router.
Firmware is the software of the router. After upgrading the firmware, it is recommended that you should reset the router and reconfigure the router.
Click Here to know more about router and network
Feb 13, 2010 | Linksys Wireless-G Broadband Router
Since you have problem with your router and geek squad is asking you to pay a big amount of monye just to make the router work, I suggest you contact Linksys tech support so they can help you with your concern and they are free and open 24/7, this is there number its 800-3267114.....
Nov 30, 2008 | Linksys Wireless-G Broadband Router
Problem with Setup Wizard for Linksys 2.4 GHz Wireless-G Broadband Router
Since you're having problem in setting this router up, the best to way to set it up is by doing a mnual configuration and you dont need to use the setup CD that came with it, I'm suggesting you to call the linksys tech support and they will walk you through on the manual setup it will only take about 10 minutes this is the number 800-3267114.
Hope that helps.........
Aug 13, 2008 | Linksys Wireless-G Broadband Router
Can't go on Internet with Linksys Router
log into router by entering its default web page into your browser usually. then run tests and save.Easy
Apr 11, 2008 | Linksys Wireless-G Broadband Router
What is the model No. of the router ?
You can open the setup page by typing in the address bar of Internet Explorer / Firefox.
The default password for linksys routers is admin.
Once in the setup page, click on wireless and click wireless security. There you'll find the wireless security keys.
Hope that helps :)
For information on wireless security, click here.
For the updated list of firmwares, click here.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
441 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
