Question about Magic Chef MCD1311ST Microwave Oven
Cook time button problems
Our Magic Chef Microwave oven MCO153UB keeps giving us the (+) sign when we hit the the cook time button and we are not able to program the time needed to cook food. Any thoughts on why we can't use the cook time button?
  • Magic Chef Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Please reply back here and let us know if the hard reset doesn't fix it.
It may have a bad door switch, and we can help you check into that. The first test for that is to try it while gently lifting up and then while gently pushing down on the door.
If you don't have your owner's manual, you can download it here:
http://www.mcappliance.com/products/otrdetail.asp?record=yes&modelname=MCO153UB
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
My magic chef microwave runs, but it does not heat. Is it worth trying to repair?
When you hit "Start" to microwave, note whether the inside light, cooling fan, and turntable all come on.
Also note when it's trying to cook whether there are any unusual noises or whether it's louder or quieter than usual.
I have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here: http://www.microwavecontrol.com/mwd_ad_aug_2008_background.mp3
Please contact me directly for full details since FixYa doesn't always inform us of follow-up questions. Remind me of the full model number and FCC ID number from the tag and your detailed symptoms.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Dec 05, 2017 | Magic Chef Microwave Ovens
Magic Chef over-the-range microwave oven doesn't cook. Clock, inside lights and turntable are fine
If it lights up, the fuse is fine. On all of the recent Magic Chef's I've repaired, the magnetron has been the cause of the problem you described. Another possible common culprit is the high voltage rectifier.
Aug 04, 2017 | Magic Chef Microwave Ovens
My magic chef microwave died. I replaced fuse, and electrical works but won't cook. Why?
Most likely if the fuse blew the part that creates the microwave energy is defective, it is called the "Magnetron" Just replace the oven is my suggestion.
Nov 11, 2016 | Magic Chef Microwave Ovens
Chef Banquet - turns off after 7 minutes? Why
It appears the problem is in the keypad controller board, it will only run for 7 minutes and give a loud beep, you need a professional for this, to assess the situation.
Mar 27, 2012 | Magic Chef MCD1311ST Microwave Oven
MCO160 microwave and cook vent appliance problem--there was a power surge and now only the light works--is there a reset button?
no reset button. if you are getting lights that means you are getting power and all your fuses are good. you may have a bad control board caused by the surge
May 12, 2011 | Magic Chef MCO160UQ Microwave Oven
I've lost the book - how do you cook something at less than 100% power?
Hi, if you hit the Power button repeatedly, it will drop the power by 10% increments.
Apr 05, 2010 | Magic Chef MCM1290A Microwave Oven
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
I have a Magic Chef MCO153UB. When the unit is used to cook for 5-10 minutes you hear a distink change in the way it runs, the light stays on and the table still turns and the fan runs, but cooking stops...
Thanks for the great details about the light & turntable.
With that in mind, this is either a failing upper door switch, a failing relay or connection on the control board, or a failing magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Another helpful link:
http://www.microwavedisplay.com/doorsw.txt
There should also be a helpful wiring diagram hidden inside the unit behind the control panel.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 01, 2008 | Magic Chef Microwave Ovens
MCO160UW goes dead after 3 minutes
I returned the item to Home Depot and they took it back no questions asked.
Nov 30, 2008 | Magic Chef CMV1000B Microwave Oven
Oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
Jun 21, 2008 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCD1311ST Microwave Oven Logo
353 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
