Question about Garmin StreetPilot c340 GPS Receiver
Streetpilot c340 the message i receive is EXTERNAL POWER LOST. i an assuming that it is running on batteries- otherwise, it works well. Where can I find the lost power? I appreciate any and all info you can give me. luc y
  • 504 Answers
Usually when it says External Power Lost, it has lost the signal between the power cord and the unit (the car was turned off while the unit was plugged into the socket and on or you pulled the plug out while the unit was on). If you are receiving this message and one of the above situations has not occured, you may have a problem with the cord, the fuse or the vehicle's power socket. Under what circumstances are you receiving this message?
Posted on Apr 15, 2008
C340 is showing low battery. how do i change the battery?
It has a 12 volt power cable for the internal battery. Do you have the cable - refer to the owners manual (free download via the Garmin site) for more info. The internal battery is not normally replaced.
Nov 03, 2009 | Garmin StreetPilot c340 GPS Receiver
C340 will not come on by battery or plugged into car. Could the lithium-ion battery be bad, if so how do I replace?
Try pulling the face off and resetting it,
If it will not reset, work in the car or the house,
The battery need's replacing.
If your savvy (soldering), Ebay for battery,
or Garmin Around $100
http://www8.garmin.com/support/outofwarranty.html
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=67938&whichpage=1
Regards
Jun 19, 2009 | Garmin StreetPilot c340 GPS Receiver
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 Street Pilot
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not power on - even with soft reset
well after being on hold with garmin for 32 minutes they told me to send them the unit back and will repair at no cost.
My unit was purchased on may 27th 2007.
Jul 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Unit shuts off
I assume this message is when operating from the internal battery alone, correct? It could be that the unit is confused about the power source status... yes, electronics sometimes get confused too.
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jun 30, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Dead Garmin StreetPilot c340
The battery usually has a small charge when arriving from the factory, but it can die before it is received. You should charge this by plugging it into the car or the computer.
I just received the Garmin C340 GPS as a gift from my daughter.
Only use Garmin approved power connector either AC or DC (cigarette lighter adapter), otherwise you risk ruining your unit. The DC power adapter actually step down the voltage from 12vdc to 5vdc. Using anything other than a Garmin approved adapter can fried the unit.
Jan 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 power problem
Remove the face cover (GENTLY pry it loose by the fingernail groove directly under the GARMIN logo), press the RESET button, then reattach front cover... this is covered in the owners manual, available online.
Nov 14, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
