RCA TV RCA D61W20, Light Blinks 3 Times
On of the parts on the blue light board had a shock due to the screen leaking, i manage to find a tech gut who can seal the tube, but the problem now is that he is telling me that i have to replace the chip board (where the DVI Chip is and where you connect the signal cables). Does this make sense?, the sympthom is that the power light blinks 3 times and nothing hapens, he says the flyback transformer is working cus he can check the pulse on the chip and it gets ok, but the chip is not sending any pulse outside.
Is this a flyback transformer problem?
Or is he lying so i can buy the board?
  • rodmorf Apr 11, 2008
    The board was clean when i open the TV, right after the short circuit hapend, everytime i open the TV in the past the board did not show any fluids or nothing only the urine stains that i talk to you in the past, but once i clean those it didnt have any problems.
    The shock was on the tablets that control the blue light, there i did find fluid from the the lamps, but thats it.
    Thats the problem i dont know wich components are affected, ive already changed the board where the blue light is (The one that the fluid cause a shcok, not the same as the mainboard where the DVI chip is), but i dont know if the mainboard (where the DVI chip is) is also not working, or just the flyback transformer, like i said the mainboard was never wet.
  • 8,617 Answers
Usually when the crt leaks onto the chassis it can be cleaned and the affected components only have to be replaced I am not sure what "chip" you are refering too, but most ICs can be purchased as a replacement part. usually the entire board wont need replacing unless the traces are destroyed or replacement parts are unavailable.
Posted on Apr 11, 2008
  • Sonny Berry
    Sonny Berry Apr 11, 2008
    You should be able to just replace the affected components
  • Sonny Berry
    there is no way to tell unless its checked according to the schematics for the proper voltages.
I have an RCA D61W20 and it will not go on at all... Do I just have to change out power supply? How complicated is it? Can I get new power supply locally?
If the light blinks three times slowly it usually the deflection board. You can get a replacement deflection board from www.tvrepairworld.com which has installation instructions.
Nov 10, 2010 | RCA D61W20 61" Rear Projection Television
The tv i have is a RCA D61W20 and it will not come on . the power light goes on and off three times and nothing
Problem with main deflection board,bad electrolytic capacitors/Hi voltage circuit has bad connections,common to those RCA tv's.
Mar 22, 2010 | RCA D61W20 61" Rear Projection Television
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
Tv wont power up
if you can not turn on TV set with the power button on the TV its not astandby problem as this would by pass the standby. Theres most protec,on a set of this age, top have a poiwer regulator,vertical,horzontal/chcroma problem and is goingto need a trained tech to assist you in this repair. www.afiata.com
Aug 01, 2008 | RCA D61W20 61" Rear Projection Television
Power Button Blinks 3 times and then nothing happens
If the coolant spilled on a circuit board, there are changes that the board might be damage as this liquid is highly corrosive and also can conducts electricity while on the board.
What is the brand and model of the TV?
Apr 11, 2008 | Televison & Video
Screen is Black Power Light Blinks Three Times
bad power sorse bring the tech in unless u know how to chage outthat part
Mar 15, 2008 | RCA HD52W59 HDTV Projection Television
Rca 61 inch projection tv model D61W20
Steve,
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at jjkjjk13@hotmail.com . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
60" rca hdtv power button blinks on and off 3 times then shuts off.
the set will have to be troubleshot further to narrow it down. the set contains a processor that has shut the set down. as a tech i have special computer that can read the errors. One thing to try is to uplug the set for about 30 min the plug in listen for anyh sounds. if the light blinks...its not the main fuse.
Dec 31, 2007 | RCA D61W20 61" Rear Projection Television
RCA projection televeion problem.
take your tv to a tech for repairs the tv power supply or related circuit is defected.good luck
May 14, 2007 | RCA D61W20 61" Rear Projection Television
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
