Durabrand PSTB-1 Free view box - code for One for All remote
I've just got a new One For All remote (6 in 1 0 URC7562) , but cannot find the code for my Durabrand PSTB-1 freeview box.
Can anyone help ?
Thank you.
Sutters
SOURCE: Durabrand DU1301
Try Emerson codes for the DU1301. 092 worked for me with my Brookstone remote
Posted on Dec 25, 2007
  • 5 Answers
SOURCE: Need a remote code for a Durabrand DWT1304A TV
I bought the "3 in 1 easy to use" universal remote from Radio Shack for $5.99 and used the Durabrand Codes in the insert. It worked perfectly.
Posted on Dec 27, 2007
SOURCE: Lost code sheet for RCA remote RCR450C; Durabrand TV DU 1901
CUALES SON LOS CODIGOS PARA UNA TELEVISON CELERA DE UN CONTROL RCR450C?
Posted on Apr 02, 2008
SOURCE: durabrand dvd player code
Here is the code for the dvd player
0449, 0405, 0446
code for the tv/dvd combo
0189, 0135, 0157, 0153, 0254, 0458, 0217.
website to find the other codes if you need.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
have a good day walmart shoppers.
Posted on Jan 07, 2009
jimlan
  • 159 Answers
SOURCE: how to put code in for the box super usb/starview 4
C & W 5C 01 09/01/09
00= 7D 9B 0E 8B 69 3F E7 34
01= EF 38 DF 11 3D 85 FE 2F
Telewest 5A 01] 23/12/08
00= E7 D3 69 2E 6F 38 EA 78
01= E8 C9 E5 6E B0 49 53 F5
NTL 54 01] 09/01/09
00= 2E E9 B1 3F F7 F8 53 B2
01= 97 9B 22 E0 5B 13 B1 C7
Posted on Jan 15, 2009
What is my dwt1905 durabrand tv code, because im tryna set up a phillips srp200327 universal remote but dont know the tv code nor remote code, please help
Check these codes. 1061 1203 1177. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 21, 2013 | Durabrand Televison & Video
Nead coads for urc7562 remote have no manual
Greetings - The codes for all the TVs supported by the URC-7562 are located here:
http://www.symdesign.com/codes.for.one.for.all.6.urc-7562.html
Happy Clicking, Mikeywaf
Mar 03, 2011 | Televison & Video
Have a durabrand 17 inch w/no remote. I have a rca universal remote- what is my code????
durabrand is an off-shoot walmart brand. you will have to do a code search on the remote and hope for the best.
  • Manually turn ON your device (TV, VCR, Cable Box)
  • Press and "HOLD" CODE SEARCH
  • Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  • Release CODE SEARCH.
  • Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  • Once the device turns off, press and release ENTER.
  • With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
  • Jul 11, 2009 | Televison & Video
    I would like to change regions on my portable Durabrand DVD player model PDV-722
    Alright, just follow these steps and let me know if you have any problems or questions
    1. Power and switch on the Durabrand DVD player.
    2. Open the DVD disc tray tray or lid.
    3. Press Stop.
    4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
    5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
    6. Press OK.
    7. Close the disc tray and press Standby on the DVD player front
    Dec 19, 2008 | Televison & Video
    Durabrand pdv-709
    Turn Player On
    Open Disk Tray (Leave Open)
    Using the Remote Control Press 3 5 9 7 3 5
    Select 0 (Zero) For Region Free (MULTIREGION) or 1 ~ 6 For Region Specific if Required
    Dec 03, 2008 | Durabrand PDV-709
    I need the RCA remote code for Durabrand tv
    Since the Funai code does not work, you have to use the CODE SEARCH feature.
    The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
    Programming a Device using CODE SEARCH
    1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
    2. Press and hold CODE•SRCH.
    3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
    4. Release CODE•SRCH.
    5. Press POWER repeatedly until the device turns off (you may have to press up to
    100 times).
    6. Once the device turns off, press and release ENTER.
    7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
    repeat steps 1-7.
    Programming Your Universal Remote
    Nov 17, 2008 | RCA Universal Remote Control
    Need code for durabrand portable dvd player
    3. Press Stop.
    5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
    6. Press OK.
    The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
    If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
    1. Power on the DVD player.
    2. Open the DVD disc tray or lid.
    3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
    4. In DVD region code menu, press Enter until come to region 9 (or 0)
    5. Press Play.
    6. Close the DVD tray or lid.
    For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
    1. Press Open to open disc tray.
    2. Press Clear.
    3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
    4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
    5. Press Standby button again to power up the DVD player.
    Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
    For Durabrand DP305, try the following DVD region code unlock hack instead.
    1. Turn on the DVD player.
    2. Press Open/Close button to open the disc tray.
    3. Press Setup.
    4. Press 8 - 8 - 8 - 8 (8888 continuously).
    5. Press Next.
    6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
    7. Press Play.
    The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
    2. Press Setup.
    3. Go to “Preferences”.
    4. Press Play.
    5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
    6. Press Left, Down.
    7. The current region code will be displayed.
    8. Press 0 for region free.
    Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
    Jun 05, 2008 | Jensen JR400 Remote Control
    Want to use cable remote 4 tv as well
    reade the booklet that came with the cable box to get the program #'s for the remote to control you tv as well
    Dec 25, 2007 | Durabrand DWT1905 TV
    Remote control codes for freeview and dvd recorder
    According to the booklet you have to enter the code 119 for a Goodmans TV, however it does not work with my Goodmans portable TV and even quick search / autoscan doesn't find the TV.
    Nov 25, 2007 | Jensen JER-422 Universal Remote Control
    Durabrand model BH2004D
    I am not sure about Direct TV but dish network does not allow the hookup to go through their box...it must go through the TV only. Speaking with Duraband at 1-800-256-2487 confirms you have to have a Duraband remote and universals won't program to it. Ask for parts dept. and order a new remote. Sorry - not good news for me either!!!
    Dec 09, 2006 | Durabrand DWT1905 TV
    Televison & Video Logo
    81 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
