Question about Memorex MVD2042 DVD Player
POWER SUPPLY Is anyone offering an on-line service to purchase a schematic for the MVD2042 DVD player? I am unable to identify the following component with the following markings: COSMO 1010 817 E03 C
  • COVBRIDGE Apr 11, 2008
    I HAVE A PIONEER DVR-320 WHEN THE POWER TO THE HOUSE CAME BACK ON I COULD NOT GET THE DVD POWER TO COME ON I CHECKED THE FUSE AN THAT WAS OK
  • 2,307 Answers
It looks like that is your optoisolator and the part markings are the 817.
Check here for the data sheets.
Posted on Apr 11, 2008
How check pcb after lightning strikes??
Over voltages as little as 20% greater than expected (under the right circumstances) can cause components to fail with no outward indication of failure. Other times, these same or greater voltages will obliterate a component and without the benefit of a schematic will make identifying & replacing it impossible.
Nearby lightning strikes often cause multiple components on different PCB to fail at the same time, complicating troubleshooting significantly. Faults can appear on power supply PCBs and in the RF stages along antenna / cable inputs and out to cable boxes DVD players, etc.
These are usually not fixed by DIYers without specialized test equipment and manufacturer's service manuals.
Jan 30, 2015 | Televison & Video
Why does the dvd player stays on standby?
the reason it stays on stanby is caused by a bad compasitor on the power supply board u can buy a replacement compasitor at a radio shack or somewere that would sell one.
Jul 08, 2012 | Memorex MVD2042 DVD Player
No power
The outlet that the unit plugs
into... Is it 'hot'? Plug in a known working Table
Lamp. If you have power, the problem is the unit.
Where the cord goes into the unit, locate the Power
Supply. Carefully check for any cracked, blackened,
or broken components. My educated guess is that
a small fuse blew, as did the Metal Oxide Varristor,
which is either a large blue or red disc shaped component
near the power transformer. If the fuse is blown black
inside the glass, this indicates a short, and would require
an Ohm Meter to locate it. If the fuse is blown so that
the element inside just melted open inside the glass,
this indicates an overloaded condition, and would require
that the fuse be replaced with a rating 1/4 amp greater
than the original fuse. Why? because most fuses are
under rated to insure that they will need service to keep
people like me from starving! Trust me on this one.
good luck!
Jun 26, 2010 | Memorex MVD2042 DVD Player
DVD player won't turn on. The red standby light is on. But the player does not work. I've tried unplugging it for 30 seconds but no change
If you didn't have any or have a good power strip the internal power supply could have gotten damaged, if it is under warranty get it replaced. And make sure you have a power strip for electronics at a mininum.
Mar 15, 2010 | Memorex MVD2042 DVD Player
Does not come on?
hi, your memorex dvd player has a circuit that generates the different voltages to supply to the different operational circuits in the dvd device(micrprocessor, spindle,sled motors,preamplifier etc.)it's called a power supply and more that likely it's the circuit that stopped working. It might be a good time to replace it because the repair cost could be very close to the price of another one.
Jan 08, 2010 | Memorex MVD2042 DVD Player
My Memorex MVD2042 DVD player isn't getting any power
If you are plugging your DVD Power Plug into the TWC Box. Unplug it and plug it into a 'known' hot socket, (wall..con strip.etc.). Ensure the AC plug is inserted fully into the DVD player. The TWC AC connection may be disabled.
Read Ya,
z
Jan 01, 2010 | Memorex MVD2042 DVD Player
Put dvd in starts to spin but stops and displays no disc
ive seen this in countless DVD players either 1.the laser mech is toast or
2. the laser driver cog's are missing teeth
either way you need to replace the laser mech you can normally order one from a electronics service center to fit or you can contact the company/manufactuer and see if you can get a laser mech for the unit
now most cheap DVD player manufacturers do not supply spare parts as there made on the cheap in china and should when faulty be thrown in the bin and a new one be purchased! because it is not worth fixing!
hope this helps,ben
Aug 10, 2009 | Memorex MVD2042 DVD Player
Sony DVD-NS575P Power Supply
well I use to buy these things at servicing stations, depending what brand your dvd was.
but I sugest to buy a new dvd player, there is a posibilities that the high voltage just blew off some parts and components too.
BUT.. try to check your fuse first maybe thats the one just blew off. change it and try it again. at this time make sure everything is good and ready to go, and test.
May 10, 2008 | Sony DVP-NS575P DVD Player
AKAI DVD PLAYER FIXING
Hello NOUSHADK,
I have good news and bad news for you. I'll give you the good news first. You know that new DVD player you have been wanting but never could buy because you already had a DVD player?
Well, let's just say that you don't have that problem any more. When you dropped that screw on that resistor, you not only caused the fuse to blow, but you took out a few other components with it. This type of power supply is called a switching power supply because it takes AC voltage and then converts that AC voltage to DC voltage to power part of the circuits in the DVD player, then it takes some of the DC voltage produced and uses it to power an oscillator which provides a switching action for a Power MOSFET which is used to drive a switching transformer and then that voltage is converted into DC voltage for the other circuits not powered by the first power supply. Now this creates a problem, because when these types of power supplies blow out they take a lot of components (active and passive) with the blown out component.
Now for the bad news. These types of supplies are very seldom repairable, not because you can't find the parts and not because you cant find the layout, but usually because the parts are hard to find, in the case of the MOSFETs, the Switching Oscillator, and other active components.  Also, the schematics for these devices are not to be found anywhere even by locating the manufacture. This is because most of these units are put together in Taiwan or in Bangkok and then branded by a company, meaning the company whose name is on the unit is not the company who manufactured the unit. So schematics and service diagrams are usually not to be found.
I know this may not help you, but you can try to find the Power supply manufacture by using google, and getting them to send you a new board, or you can try to repair the board yourself, but remember you will have to hunt down at least 3 bad active components and a number of bad passive components.
Thank you,
Shuttle83
Apr 22, 2008 | Televison & Video
Memorex 6 Hi Fi Stereo DVD player
just turn off the progeressive scan on the back of your dvd player.
Jan 20, 2008 | Memorex MVD2042 DVD Player
Memorex MVD2042 DVD Player Logo
121 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
