No mouse cursor visible on monitor
My mouse cursor does not appear on my monitor. I have restarted and shut down my PC but the cursor is still not visible.
I have gone to my control panel to change the properties of my cursor but still nothing.
Tried downloading mouse drivers but still nothing.
I tried switching mice between the cordless one to the USB mouse that I normally use, but still nothing.
I'm getting tired of using my keyboard to navigate my PC.
Kindly assist.
    President:
  • 2,712 Answers
Could be spyware, virus or a failing hard drive.
Download Ad-Aware® SE Personal Edition, a free program that you can download at:
http://www.lavasoftusa.com/support/download/
Check for updates before running program. Then follow the directions here to do a full scan:
The following explains how to set Ad-aware's settings to perform a "Full Scan."
In Ad-aware click the Gear to go to the Settings area.
The following items should be on a green check, not on a red X.
Under the Scanning button:
Scan within archives
Under Memory & Registry, Check EVERYTHING
In Check Drives & Folders, make sure all of your hard drives are selected
Under the Advanced button, check ALL under Log detail level (this makes it easier for visitors to the Lavasoft Support Forums to see what options you have selected should you require assistance.)
Under the Tweak button...
Some of these may not be an available option, depending on your version of Ad-aware and your version of Windows. Do not be concerned if you cannot select a certain item.
In Scanning Engine:
Unload recognized processes during scanning
Include info about ignored objects in logfile, if detected in scan
Include basic Ad-aware settings in logfile
Include additional Ad-aware settings in logfile
Include used command line parameters in logfile
In Cleaning Engine:
XP/2000: Allow unloading explorer to unload shell extensions prior to deletion
Let Windows remove files in use at next reboot
UNCHECK: Automatically try to unregister objects prior to deletion
Click Proceed to save these settings. When you would like to perform a "Full Scan," switch the scan mode from SmartScan to Custom.
After running Ad-aware, you must reboot your computer. It may be necessary to run Ad-aware two or three times if you have a lot of spyware, rebooting each time in between.
Where it says,"In Ad-aware click the Gear to go to the Settings area", on the top of the Ad-aware window, there are 5 symbols, click on the one that looks like a gear.
Go to: http://sarc.com/ Scroll down and click on,"Free Online Virus and Security Check" Write down exactly anything it finds, then return to: http://sarc.com/ and do a search for what was found. Symantec usually has a removal tool and/or directions for removing. manually.
Regarding the Hard drive, check out what PCWorld offers at:
http://www.pcworld.com/howto/article/0,aid,105869,00.asp
Hope this helps!
Posted on Apr 17, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    I would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Unable to move cursor on lenovo x61
Are you trying to move the cursor with the trackpoint, a usb mouse, or the pen? Have you tried restarting your computer? Restarting would likely solve the problem. If you can't move the cursor to the start menu, you can open the start menu with the windows key, use the arrow keys to navigate to the power options. Use enter to select the power options and shut down or restart the computer. If this does not work, press and hold the power button for 5 or 10 seconds to force the computer to shut down.
What happened before this occurred? Did you install any programs or updates recently, or change any settings on your computer?
Apr 12, 2015 | Lenovo ThinkPad X61 Tablet PC
My gateway laptop cursor is frozen
This is caused by conflicting drivers.
Start off in Safe mode.
press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
Then you should be able to use the mouse, see what programs have been recently installed that may have caused the conflict.
Sep 26, 2014 | Computers & Internet
Where do I turn off my laptop
Power button is top left corner of keyboard above the "Esc" key.
If you are trying to shutdown from Windows 8, follow these steps:
1. Mouse over the little gadget in the lower right corner of the screen. (You can also move your mouse cursor to the upper left corner; same result. Or, you can press Windows-C on your keyboard.)
2. In the slide-out menu (known as the Charms Bar) that appears, click Settings.
3. Click the Power button, and then click your desired action: Sleep, Shut down, or Update and restart.
Mar 07, 2014 | Dell Computers & Internet
Inactive cursor on my lenova laptop
I', sue you have shut down, unplug, remove battery, plug in , reboot. Are you using the touchpad or external mouse?
Dec 20, 2012 | Lenovo Computers & Internet
THE CURSOR WONT MOVE WHEN YOU ROLL THE MOUSE CANT CLOSE WINDOWS DOWN
Hold in the main power on button until the computer shuts down -windows will automaticly safley shut down .
once it shuts down restart it and hopefully the mouse problem will also be fixed
I hope this helps
Andrew a
Mar 28, 2011 | Computers & Internet
Cursor will not move on screen when using touch pad i've shut the computer down and restarted but cant get the cursor to move
Please press Fn+F9 key to ensure the mouse pad isn't disabled. The key should have these symbols on it.
Hope this helps,
NOLA Tech
Jan 30, 2010 | Toshiba Satellite Pro P300 Notebook
When I restart the computer, the keyboard and mouse do not work. The mouse won't move the cursor and hit cntl alt del on keybourd and nothing happens. I have tries three mouses (one wireless) and two...
Use wired mouse and keyboard (not wireless) and change the USB port you are using to another one.
Connect them directly to the computer, do not use USB hubs.
If no joy reboot in safe mode: turn on your computer and immediately press F8 repeatedly until you get the Advanced Boot screen. Select "SAFE MODE" and press ENTER. After that, restart in normal mode.
Thank you
TechSaver
Jan 21, 2010 | Dell Dimension E520 PC Desktop
Mouse on laptop
Try and shutdown you system and then put it back on note donte restart it. if the problem persist, go to control panel and then mounse settings there try and increase the cursor's image or if your system is using a customized theme maybe you should revert back to windows theme. good luck
Jul 26, 2008 | Gateway Solo 5300 Notebook
Mouse Cursor Frozen
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Jun 13, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
398 people viewed this question
David Payne
David Payne
