Question about Akai LCT2060 Television
Input Signal Out Of Range
About last week my hp computer after i have switched it on i was expecting it to boot to my desktop interface but rather input signal out of range was what appeared  on my screen so i tried my system unit with another monitor and it was working after that i also tried my monitor with a different system unit and it also worked so after that i was a bit confused and i brought back my system unit and my computer together and connected them and it still gave me input signal out of range so i realized my hp keyboard was cordless and even thought it is not working but after i went to the system bois and had made some changes i became certain that it was working so i would be very glad if u can assist me solve this problem as soon as possible
Thanks
Signal out of range. When i boot up the screen works during setup and then when it boots the tv prompts me that signal out of range.
Press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Posted on May 18, 2010
  • 1 more comment
  • DaOld Man Nov 19, 2010
    This worked great!
  • dwyere78 Nov 24, 2010
    This fixed mine to FANTASTIC advice
  • alipgh2011 Jan 27, 2011
    Perfect!! Thanks
  • 472 Answers
Start your computer.
When the bios info page turns to black (as if about to start loading Windows) press F8 a few times.
A page will pop up with options to start Windows.
Choose Safe Mode then press Enter 2 times.
If you still get to the Windows Logo page then just hit the reset button and do it again.
Once in Windows, goto the Display Properties.
(right click on the desktop and select display properties)
A window will pop up.
The last tab at the top of that window is Properties, selct it.
You will see a slider on the left side in the window now open. Slide it back to 800x600 or 1024x768.
Click apply, then OK.
Close the box and restart the computer.
Hope that helps =)
Posted on Apr 11, 2008
SOURCE:
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
Using a HP L1506 Monitor on a HP Pavilions a 867c computer and has worked, but now receiving "VGA input: no input signal" with window on monitor, followed by "Monitor going to Sleep" and it does. Worked...
First of all, boot your system without the monitor connected to it and when you feel that it's booted upto logon screen (or if you haven't assign password it'll directly logon to the desktop, power on the speaker to make sure you can know it's done) connect the monitor. If this isn't successful, please turn off the system and remove the cmos battery, leave it outside for few minutes and again reinstall it. Boot again normally. Still having the same problem? then let's try another method. Did you see the bios loading (black screen with white text during startup) when you power on the system? If so, press F8 several times while it is booting and select "Safe Mode" and restore your system to previous state. Do let me know if this isn't possible. Good luck Thanks for using FixYa.
Jun 10, 2010 | HP Pavilion F1703 17" LCD Monitor
What is the parts of a monitor
Part Number:RK284AA#ABA
* Display Type LCD display / TFT active matrix
* Built-in Devices Microphone , Speakers
* Width 20.6 in
* Depth 11.4 in
* Height 18.9 in
* Weight 19.8 lbs
* Enclosure Color ( The image of the product displayed may be of a different color )
* Localization English / United States
* Display (projector) image aspect ratio 16:10
* Image Contrast Ratio 1000:1
* Diagonal Size 20 in - Widescreen
* Dot Pitch / Pixel Pitch 0.282 mm
* Max Resolution 1680 x 1050 / 60 Hz
* Max Sync Rate (V x H) 76 Hz x 82 KHz
* On-Screen Controls Switch video input , Brightness , Contrast , Image control , Color adjustment , Quick view , Language , Management , Information , Factory reset , Exit
* Controls / Adjustments Tilt
* Tilt Angle 30
* Signal Input VGA
* Digital Video Standard Digital Visual Interface (DVI)
* Type Microphone|Speakers
* Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
* Connections - DVI-Digitaligital , - VGA
* Microsoft Certifications Compatible with Windows 7
* Form Factor Internal
* Voltage Required AC 120/230 V
* Power Consumption Operational 65 Watt
* Power Consumption Stand by / Sleep 2 Watt
* Min operating temperature 41 °F
* Max operating temperature 95 °F
* Operating humidity range 20 - 80%
* Service & Support Limited warranty
* EPA Energy Star Compliant Yes
* EPEAT Compliant EPEAT Silver
Feb 15, 2010 | HP W2007 Desktop Monitor
MS Vista patches broke my Desktop on my HP PC
after switching on the computer press F8 & Choose safe mode to boot the system & Restore the system in previose state & Before doing this make sure u backup the C Drive.
Don't Forget to Vote
Max
Jun 29, 2009 | Computers & Internet
MS Vista Windows patches broke my desktop
reboot the computer and then press f10 this should get you a screen with a text line that says safe mode,with net or command scroll down to last settings that worked and try that ps. you really need to make a recovery disk. its that important.
Jun 29, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Input signal out of range
You could try going into safe mode and make sure the correct drivers are installed and if they are then you can then set the correct resolution.
Feb 28, 2009 | Dell OptiPlex GX260 PC Desktop
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Oct 30, 2007 | HP Pavilion F1523 15" LCD Monitor
When i start my computer it doesn't open windows, well it basically does all the booting up and up until it has to say "welcome" it then presents a black screen with the message: input signal out of range....
The video driver isn't set up correctly for the computer. You need to boot into safe mode - after powering on the computer, press the F8 key. You will be shown a menu. Choose Safe Mode with networking. The computer will boot using a very basic video driver. Right click on the screen and select properties. Click on the advance tab. Click on Driver => Advanced => Update driver. Once the driver has been updated. Go back to the drivers tab and click on mode. Select one of the modes. Close everything and restart your conmputer normally.
Oct 25, 2007 | Dell OptiPlex GX260 PC Desktop
Akai LCT2060 Television Logo
6,142 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
