Question about Philips Magnavox MT2501C 25" TV
Smart lock. How do I get access code for smart lock on my tv?
  • Randen Apr 12, 2008
    Thanks for the offering but 0711 did not work I tried several times. Have another ?
    President:
  • Philips Master
  • 1,779 Answers
Try 0711 as your default code, you may have to enter it twice...Let me know.
Posted on Apr 11, 2008
How to operate a LG smart tv
hi linda.
Press the Smart button on the included remote to access the Smart Home menu. From there, the LG Smart TV will take you through a setup wizard. Follow the onscreen prompts to connect to your home's Wi-Fi and your cable box. Once connected, you'll be able to access online videos, apps and more.
How to Set Up Your LG Smart TV: Geek Squad - Best Buy
https://www.bestbuy.com/site/tech-tips/set-up-lg-smart-tv/pcmcat748301880322.c?id...
How to operate LG smart tv Google Search
Nov 07, 2017 | LG Televison & Video
Is Samsung model # UN55D6050TF a smart TV? Model Code:UN55D6050TFXZA Version No: H301 S/N: Z3333CAB801334D Is it a smart TV with Apps already on it?
You have to connect the TV to internet first & access the smart function, then the Samsung internet Apps will be updated.
Apr 26, 2017 | Samsung Televison & Video
How do I unlock smart lock, I have the remote, but I don't know the 4 digit access code
When prompted to enter the code enter 0711. This will allow the TV to be operated.
Feb 16, 2016 | Televison & Video
Magnavox tv model # 13mt1532-17. Need code to disable the smart lock system. Can you help?
Hello
I assumes that you did gorget the code that you have set to Smart lock, and posts this solution.
If you ever forget you smartlock code, enter [ 0,7,1,1 ] code is the factory default, and can be used to enter and create a new acess code. OK.
Feb 10, 2012 | Televison & Video
Need to remove smart lock from tv i know excess code.can not get satellite on it.
I changed to another TV, which did not have the smart lock on it. It is fine Thank You for your help.
Dec 30, 2009 | Televison & Video
Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Jan 01, 2009 | Philips TP2784C TV
Lock access code
Just follow the steps carefully and you should be up and running again. Thanks for the model number.
1) To reset/change the SMART LOCK code, follow these steps.
Press the MENU button on the remote to display the on-screen menu.
Press the Cursor Up (also known as CH + button, above menu button) or Cursor Down (CH - below the menu button) to highlight SMART LOCK. Then press the Cursor Right (VOL + button to right of menu button) to display the SmartLock ACCESS CODE screen.
Using the numbers on the remote keypad, enter 0 7 1 1. " INCORRECT CODE" will appear on the screen. Enter the code 0 7 1 1 again.
Cursor Down to CHANGE CODE and enter 0 7 1 1 and then CONFIRM CODE and enter 0 7 1 1.
Press the STATUS / EXIT button (left of CH +) to save the new code in memory.
2) If the grandkids have locked out any channels, then you will have to perform the following steps:
Press MENU, highlight SMART LOCK, right arrow, enter 0 7 1 1, confirm by entering 0 7 1 1 again.
Cursor to BLOCKING OPTIONS, right arrow, and highlight CLEAR ALL, right arrow.
You should then see CHANNEL....ALL, LOCK....YES, ALL UNLOCKED.
3) To turn SMART LOCK off, follow these steps.
Cursor to BLOCKING OPTIONS, right arrow, and highlight BLOCKING OPTIONS, right arrow,
Aug 19, 2008 | Hitachi 51F500 51" Rear Projection...
Smart lock
If that function was put in use by the previous owner, the fastest way to change the parental lock out would be to contact your friend and get the access code from them.
Since the set probably uses a bit of flash memory to store the access code and other settings, if an individual chip, that would have to be physically removed and replaced.
If you can locate service information on your set, it will likely contain a procedure to set the memory back to factory default.
Jul 06, 2008 | Philips Magnavox 20MT133S 20" TV
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Philips Magnavox MT2501C 25" TV Logo
201 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
