Question about Vulcan Convection Oven - VC44EC-208-1
Ignition The oven will not ignite. I do not hear the ignotor clicking either.
If you smell gas, then check the ignitor circut first. A spark ignitor usually has a grey or orange wire, leading from the ignitor to the input circut. Try testing the terminal where the ignitor is powered, when the unit should be calling for ignition. If there is ample voltage to the ignitor, but it will not spark, shut off the power and the gas to the appliance and remove the pilot assembly. The ignitor will either unclamp or unscrew from it, and can now be replaced. Check to see if it is properly spaced (which it should be if undisturbed), or if any deposits are on it. Sometimes they can be properly spaced or cleaned to work once again.
- Ian Miller
Posted on Dec 18, 2009
Blower motor not turning on
Posted on Nov 09, 2009
Backfire
possible bad ignter .The glow or spark may not be hot enough for the electronics to to realize it's trying to lite.problem related to ignition and or ignition control module.ask your parts dealer about these parts.
Jul 28, 2013 | Baxter Ovens
My maytag oven CRG 300 gas oven will nit light when wanting to use the oven. the top works well. i have pilotless ignition. wht will it not light. I hear the ignition and hear gas.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jan 29, 2011 | Ovens
Whirlpool Gold model #GS395LEG oven control panel shows it is preheating, but you don't hear the click and the gas doesn't ignite. Ten minutes later, no heat!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 09, 2010 | Whirlpool RBD305PD Electric Double Oven
I have no power (120VAC) coming from F2 terminal of Fenwall 1466H Ignotor Control. Draft inducer will turn on and oven is inop due to this. I would like internal connections of controller to verify loss of...
I'm assuming you meant to say your draft inducer will NOT turn on. I unfortunately do not have a wiring diagram in front of me (they are usually stickers inside the burner compartment) but you should check to make sure your hood fan is running and that the air switch for the hood fan is closed, your ignition module wont receive power until the hood airflow is verified.
Sep 06, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Main burner ignites, but cut-off soon after.
Having never seen one or heard of one , I would try the manufacturer's website for tech support . or contact a LOCAL gas service
Sep 11, 2017 | Vulcan GCO2D Gas Single Oven
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Having problem with the bake igniter not always igniting. Hear clicking, but no flame. Doesn't happen all the time.
You may have a weak igniter or a bad safety valve depending on the model. Let me explain. Their are many different types of oven valves. Some use glowbar and others use standing pilots, still others use a igniter with a safety valve and flame detecting switch. So you do not have a generic problem. To get a specific answer I will need the model number. Since you say you hear the clicking I am gonna assume that is a standing pilot with spark igniter nd safety valve/flame switch. In that case you either need to replace the valve if it is a combination one with thermocouple and valve all in one package or the flame detecting switch if your model has indeed a stand alone falme switch I have some repair photos: HERE
Jan 22, 2010 | Kenmore Ovens
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
VulcN MODEL gc04C CONVECTION OVEN WON;T IGNITE ER-05 CODE
Like an electronic igniter for a gas grill? I believe you can pick up a replacement. Call Lowes or Homedepot. I know i have saw individual igniter's before my friends bought some for my friend and I when we were little to make potato cannons.
Jan 22, 2008 | Vulcan GCO2D Gas Single Oven
Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
Vulcan Convection Oven - VC44EC-208-1 Logo
247 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
