Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
PT-53TW53 resistors needed
I was wondering if anyone knew the parts numbers for r7011 and r7015 they are 2 resistors i need to get. are they the same resistor or 2 different wattage/ohm? and does anyone have any recommendations on where to get said parts?
  • toolfreak316 Apr 11, 2008
    ok. soldered in 2 new resistors. hooked up all the cables turned on the set and one of the resistors blew. did i hook up the cables incorrectly or was my soldering not up 2 snuff? or is there bigger problems? does anyone possibly have a schematic for this set?
  • 2,326 Answers
They are 2.2 ohms, 5%, 2 watts.
You can try digikey.com or radio shack.
Posted on Apr 11, 2008
  • Jaime Hernandez Apr 11, 2008
    You can also check this site with the panasonic part numbers:
    ERX2FJ2R2H
R517 please give value, thank you model # PT-53TW53G D BOARD
R517 is a 10K ohm 1/4 watt carbon resistor part number ERDS2TJ103T
Jul 23, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic tv doesn't turn on
just check the fuse it might have been blown.....also how old is you tv ?
Aug 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
R517 of main board is burned out - TV won't turn on.
lo que puede hacer es medir el ohm de la resistencia y * 2 pero desde el terminal hasta la mitad de la resistencia
Aug 25, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Dble vision
Did you replace the convergence resistors also? Thats most likely the problem as often the resistors need replacement as well.
Aug 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Replaced 2 resistors one burnt up. please help
They would only burn if your convergence ICs are bad so if you didnt change the ICs with the resistors they will keep burning.
Apr 29, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Parts for panasonic pt-53tw53g
r7011 = 2.2 ohm 2 w...
r7015 = being researched....
Partstore.com ...........................................T.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pt-53tw53g
It is a 2.2K ohm resistor, here is the info out of the service manual.
R7031
ERJ6GEYJ222V
RES M 2.2K-J-1/10W
hope this helps.
Apr 01, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pt-53tw53 tnp2a1h046 schematics
Cheap IC's = open resistor
Replace with X 480293 Kit Use IC's from kit to save $$.......T.
Mar 15, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Identifying resistor
look at the location marking on the pc boaed and record the number of the resistor  and then we can find the value of it via schematic /parts list ,also require model #
Oct 04, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
