Albatron PX865PE Pro II CPU temperature readings
My Albatron PX865PE Pro II mainboard with Pentium 4 2.4C with retail HSF installed shows CPU temperatures of 48 degrees Celcius when idle and 67 degrees C max after running cpuburn for quite some time. The lowest I've seen is 47 within a minute after turning on the totally cooled down PC. When I turn off the PC and measure the temperature at the top of the heatsink, it does not get above about 28 degrees C (it takes some time to get there). Are there others with this mainboard who have the same readings, or who do get normal readings? Eddy problema de audio
Hi Eddy,
These temp reasdings are toooo high.
I have been working with Electronics for over 30 years and the best operating temperature is less than 30degs Cent.
There is water cooled computer chips now in computers and your might have one of these or yours could be a fan driven type.
Some fan driven types ramp up in blade speed as the temp rises I would suggest that you have your PC looked at pronto...
Good luck... its best that you have found this fault before a burn out happens.
Cheers from YUBEUT
Posted on Apr 21, 2008
Need to locate schematic for albatron px865 pe pro
http://albatron.manualnguide.com/manual-albatron-px865pe here you go jim
Oct 09, 2013 | Albatron PX865PE Pro Motherboard
Found the Problem with albatron px865pe pro with multimedia and usb problems. When I install the software somehow it miss the drivers so manually intsalled the drivers off of cd that came with the pci...
if you are running windows,
  • Control Panel
  • System
  • Hardware
  • Device Manager
Make sure that your drivers were not installed as Unknown Device:
  • Uninstall
  • Reboot
  • System will try and reload drivers after reboot, or you can manually load then
  • Control Panel
  • Add Hardware, system will look for new hardware, follow steps
Feb 24, 2011 | Albatron PX865PE Pro Motherboard
I dont have driver for multimedia audio controller albatron pro mainboard
U may download sound drivers from any of the the following link:-
http://driverscollection.com/?file_cid=40476521283ce81c82828c2c459
http://www.findmysoft.com/drivers/Albatron-PX865PE-Pro-V2-0-Realtek-655-650-Codec-Audio-3-51-sound-card-driver.html
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Albatron-PX865PE-Pro-V20-Realtek-655-650-Codec-Audio-3-49.shtml
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Albatron-PX865PE-Pro-V20-Realtek-655-650-Codec-Audio-351.shtml
Nov 01, 2010 | Albatron PX865PE Pro Motherboard
Albatron motherboard px865pe pro. while trying over clock the cpu the system did not reboot after changing the settings in bios. i proceded to reset the bios to defaults by using the cmos clear...
Start the computer.
Enter BIOS SETUP.
Choose Load Default Settings.
Choose Save & Exit.
Check that the fans are working, and that the computer is not over-heating.
Sep 26, 2010 | Albatron PX865PE Pro Motherboard
Need to purchase a new board where can i get one
I would try eBay, HERE's a Link to one up for sale as of now, but I'm sure you can find more.
Feb 09, 2010 | Albatron PX865PE Pro Motherboard
No video and no posting
Your GA-7N400 PRO2 motherboard does not have a built-in video graphics card. You need to install an AGP 8x graphics card into the AGP slot on the motherboard. When you removed the heat-sink & fan assembly the CPU starts to over heat & the CPU will shut down the system. That's why you heard the, european ambulance sound.
If it wouldn’t, you would fry the CPU. Make sure you add thermal grease on to the CPU before re-assembling the heat-sink & fan. Don't forget to plug the CPU fan power connector on to the board.
Motherboard specs;
http://www0.dealtime.com/xPF-Gigabyte-GA-7N400-Pro2
Download & read your manual. Open the link provided here;
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1756
Mike
Aug 12, 2009 | Albatron PX865PE Pro Motherboard
Manuals
Here is the page for your manual just choose your language and download.
http://www.albatron.com.tw/English/Product/MB/pro_detail.asp?rlink=Manual&no=52
Hope this helps. M~
Apr 18, 2008 | Albatron PX865PE Pro Motherboard
37 people viewed this question
 Grubhead
Grubhead
