Question about Thermador Kitchen Ranges
Infinite switch Harper-Wyman infinite switch for the electric griddle (15A, 120V) on Thermador model GCV36G gas cooktop lasts about 2 years, then won't energize the element. Contacts look slightly burned, don't appear to have a wiping action? Is this common? Is there a solid state replacement?
  • 1314 Answers
SOURCE: Infinite Switch Replacement
one switch cant affect them all check for a central power problem low voltage weak breaker loose wires on cord loose terminals in outlet box etc.
Posted on Feb 18, 2008
SOURCE: Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Posted on Jun 03, 2009
MNfisherman
  • 11896 Answers
SOURCE: Burner Heating element doesn't heat
Check power to element with a voltmeter. If there is power, the element is bad. If not power, than switch or relay is likely faulty. You can also test them with an ohmmeter
Posted on Nov 17, 2009
pride applia
  • 232 Answers
SOURCE: Largest element heat remains high in every position
you need a new switch no dought
Posted on Dec 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Can someone describe how the
That switch controls the big burner and the middle or bridge burner. It works just like a single burner but it just does 2 functions: I have a video: HERE
Posted on Jan 29, 2010
Need discontinued burner valve for GCV36G
You can try an appliance parts supplier. There might be a crossover to a current part
May 08, 2013 | Thermador Kitchen Ranges
Hi, I need to find a place to purchase a Harper-Wyman model 5853 LP gas valve. Thank you. Dave
Hello. Generally, the best local source for LP gas valves is your LP gas provider, give them a call. Also, there are several other sources including http://www.kitchenstuff.com/items.asp?Cc=HS1077, and local plumbing supply houses. J.
Jul 09, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
Infinite switch has failed twice in the last 6 months on my JP350 elec. stove?
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 14, 2010 | GE 30 in. Profile JP350 Electric Cooktop
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Thermador Vent Gas Cooktop Model GGCV36 Serial # 89020071
Just google the repair clinic and partselect,they are selling spare parts online..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Thermador SGS36GS Gas Cooktop
Kitchen Ranges Logo
85 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
