Question about Maytag EPIC MFW9700S Front Load Washer
Maytag Frontloader MFW9700S Frontloader Disaster
4/11/08 Yikes! We bought this model in October of 2007 and were quite happy with it until this week and now I'm smelling an overripe lemon!!!! The first issue occurred about a week ago when I put a small load of laundry in before I went to bed. I woke up to find a load of soaking clothes, a torn gasket and the O-ring clamp laying in the barrel. Fortunately, it is still under warranty, so I called the appliance store. Okay...the guy comes and replaces the gasket and O-ring and says we must be overloading it. :o Next load several days later...water comes spewing out during the rinse cycle. Call repairman. Tinkers with it again. Says we must be overloading it.. Yea, okay... next load...one hour after the guy leaves...water spewing out again! Repairman coming again today. I'm smelling another lemon similar to the Neptune disaster, but I suspect I'm one of the early birds in making this discovery, on this particular model at least.
  • Paulrh May 19, 2008
    Yea same old maytag problem here too. Had a neptune finally got feed up with the door not locking and stopping in mid cycle for no reason!!! Took a shotgun to it and bought a epic 9700 and yes now i have similar problems too this other post water coming out all over floor during rinse and water flow errors. Have had three service calls with no fix at this point ready to take a front end loader to this one now!!!! NEVER WILL I BUY ANOTHER MAYTAG PRODUCT AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!
    Genius:
  • 1,073 Answers
Call a&e factory service, they will service the machine under warranty no mater what dealer that you purchased it from .
i will bet that they will after you tell them what is going on that they will replace the shock absorbers on the machine
Posted on Apr 11, 2008
Looking for agitator parts for 909278 maytag style Master
There appears to be variations of this model. Here is a link to one company who may have the parts and assistance you are seeking:
Here are the model number variations:
  1. MFW9700SB0 - Washer
  2. MFW9700SB1 - Washer
  3. MFW9700SQ0 - Washer
  4. MFW9700SQ1 - Washer
http://www.appliancepartspros.com/search.aspx?model=mfw9700s
Jul 21, 2015 | Maytag EPIC MFW9700S Front Load Washer
My Maytag washer was purchased in October 2003. Model No.: SAV3655AWW Problem: My washer is leaking from underneath. The hoses connected on the outside are very tight. Can this easily be repaired?
this coild be easy fix ... remove front cabinet and verify internal hoses or pump... if coming down bottom of tub the its tub seal and bearing and u arent gonna be happy on price very extensive repair and requires a specialty tools...very expensive usually around $300.00 parts and labor
Feb 03, 2011 | Maytag Washing Machines
Maytag the washer quits and a f20 or f11 shows up
Its a water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Apr 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
The ''control locked light is on'' how do i reset it
there is a button on the control panel, marked "control lock" hold for 3 secs to unlock, look closely its there
Nov 25, 2008 | Maytag EPIC MFW9700S Front Load Washer
1979 Maico 250 Enduro Wiring
with Steering lock on headstock and correct tank using the plug in black connector Bosch ignition - she looks great and pulls like a train.... My problem is that I am entered into an Enduro in France (I am in England) on the 14th October and the bike must have working lights.....It has a headlight and Tail light but no wiring connecting them. There are several spare wires taped up under the tank I am quite happy to carry out the wiring I just need to know the colours to use...and how to check them I have a multimeter available. It has a horn attached and I have bought a high/low /horn switch , as well as a rear brake light switch...,I have written this motoplat instruction quite a while back: http://www.ktm495.mxbikes.com/motoplat.htm Right at the bottom is the color coding for the lightning wires.,,,
Nov 10, 2008 | 2007 Maico 250 Enduro
Blowing fuses
[double post]
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
But I would wait until the authorized servicer gets there (or take it to them) to maintain your warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Maytag MMV5207A Microwave Oven
REMOTE QUITS WORKING...????????
if your TV still on warranty, it is better return it for another replacement.
cause it is the main board freeze up on you.
Apr 30, 2008 | Vizio 42 in. LCD TV
High speed spin problem
contact maytag at 1-800-688-9900 and ask whats going on and you need your machine fixed while it is under warranty, it is only covered for a year.
they may refer you to a whirlpool number but whirlpool now ownes matag so this is ok
Jan 21, 2008 | Maytag EPIC MFW9700S Front Load Washer
Daylight savings time adjustment
Go to:
http://www.emersonelectronics.ca/emerson/en/product/details/VLJT600
or
http://www.emersonelectronics.ca/emerson/en/category/list/694
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source: http://webexhibits.org/daylightsaving/e.html
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Maytag EPIC MFW9700S Front Load Washer Logo
128 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
