Question about HP Pavilion dv6000z Notebook
Tried to repair my backlight and created new trouble...
Hi, I took my old sony laptop screen apart as the backlight went.
I put in the new backlight and it solved the problem of the hissing and flickering screen.
But, o dear, now the feed, which was fine before, does not come through.
The feed from the laptop itself is fine, it's just that I have done something to the screen when taking it apart/ reassembling.
All I have now when I switch on is a white screen with a little image of a tab about 1cm long along the the left hand side near the top of the screen.
I've no idea where to go from here as I thought I had put it all back together OK and I have no experience.
Any ideas most welcome.
  • anna77 Apr 11, 2008
    I fixed it thank you.
    New Friend:
  • 136 Answers
You have dismantled the feed wire its silver and has a black tip
Posted on Apr 12, 2008
Dim screen
sounds like your backlight inverter or lamp has failed. It is worth fixing if you can find someone to do it for a reasonable price. It isn't something I would recommend trying yourself unless you have laptop repair experience. If you just want to purchase a new laptop, you can put your old one on Ebay or Craigslist. I can assure you someone will buy it as is.
Sep 24, 2012 | Sony VAIO VPC-EH11FX/B Laptop Black
I bought a new screen for my Sony Vaio pcg-71912L, but when i changed and i tried to turn on, the screen never turn on, i put back my old screen and it doesnt work either? somebody can help pls
The only thing left is the inverter board located just below the screen and is a common issue with a black screen, the inverter board drives the backlight behind the display.
Apr 27, 2012 | Sony VAIO K45 Notebook
My Sony VAIO Laptop screen is black. It worked fine, no issues2 days ago. Went to turn it on last night and it is black.. When light hits at a certain angle, I can see the desktop, I can hear the startup...
A faint and barely visible image on the screen indicates that the backlight(s) that illuminates the display isn't powering on. A device called an inverter board takes DC power from the laptop motherboard and converts it to AC power to power the screen backlight.
Before attempting anything below, be sure and remove the laptop battery and unplug the laptop
You need to take the screen apart and check to make sure that no cables are loose that are connected to the inverter board. If everything is secure, the next thing I would do is try to test the inverter board by hooking up an LCD from another laptop to the inverter and turning the laptop on to see if it lights up. If the other screen does light up, then the inverter board is likely good and your backlight needs to be replaced. Backlight replacement, unfortunately, can be very tricky for even an experienced technician, and many will opt to just replace the entire screen.
If you can't test the inverter board, then it might be worth it to order one and see if installing it fixes the problem.
Youtube is a great place to check for instructional videos on laptop repair, such as this one:
http://www.youtube.com/watch?v=jjXLR5yY7X4
Sep 21, 2011 | Sony Computers & Internet
I have a Sony Viao NS10E, all working fine and then the screen went dark, took screen out and put in an other laptop and it worked fine, put the screen from the other laptop in mine and still dark. The...
You definitely have a Video Card Error related.
  1. Find Where Your Graphic Card located (asuming your computer has a separate card for video .
  2. Check the connection from your display to your video card (these connections are very thin wires running all the way to the video card or the MB).
  3. If the second step is clarified then have your graphic card checked. or have *********** Board chip set checked for bios and fermware.
Mostly you have a connection problem.
Nov 27, 2009 | Sony VAIO PCV-W20 PC Desktop
Sony vaio aw11m- took it apart now cant put back
You need a technician to reassemble it. There are no diagrams detailing every screw.
Good Luck!
Oct 30, 2009 | Sony VAIO VGN-AW110J/H 18.4-Inch Laptop...
Screen Blacked Out...
Before taking it for repair connect it to a working external monitor to verify the video card is working. It probably will. You most likely experienced an inverter failure. The inverter supplies the high voltage and frequency required to run the backlights. In some cases it is the backlight that fails. If you are comfortable taking apart the LCD putting a new inverter is easy, it just plugs in. Be sure and verify that the cable that goes through the hinge is intact If it is damaged it is inexpensive but requires taking apart the top and bottom to replace.
Jan 19, 2008 | Toshiba Satellite A135 Notebook
Brocken psp
Try getting the backlight fixed. My psp kept doing that n my friend fixed it. He took it apart, tinkered w/ some screws, put in something new, and it was fixed.
Dec 31, 2007 | Sony PlayStation Portable (PSP) Console
D600 screen went very dim
You also might check to see if there is a HOTKEY setting for the brightness of the screen (usually FUNCTION or FN and then some key on the top row).
Replacing the backlight on an LCD is a very advanced and trouble prone procedure, unless you are good with soldering and taking things apart, you should probably use it with an external monitor or think about getting a new machine. :>|
Oct 26, 2007 | Dell Latitude D600 Notebook
Sony Wega KDF-55WF655 blue ghost problem after replacing lamp
It is a defective light engine and it must be replaced. I hope you have a warranty because Sony will not help you.
Apr 06, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
No backlighting
You need to repalce the backlight/Screen altogether, or have someone do it for you. If the backlight has cracked then no amount of reconnecting will get it to work. Try one of the many Laptop repairers online to get a quote
Dec 28, 2006 | Toshiba Satellite M35X-S163 Notebook
HP Pavilion dv6000z Notebook Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
