Question about Canon PowerShot S2 IS Digital Camera
S2 is camera
I had hooked up my canon camera to the computer to burn some cd..
i have done this before..but now i always get a memory card error when putting th ecards back in the camera to use...says card is locked..the cards are not locked and i can use them in other cameras..so i tried to format the cards in this camera..but on the menu it will not highlight the format so i can do that,,it just skips over the work format..
can you halp me
  • 1 more comment
  • braxton2006 Apr 11, 2008
    please help
    please help
  • Mike Johnson
    Mike Johnson May 11, 2010
    Can you still add photos to the card from the camera?
  • 477 Answers
If you cannot then the pins in the sd reader writer are messed up and not making good contact. the mainboard needs to be replaced to correct this problem.
Posted on Apr 15, 2008
No i cant ..but i can on another camera...
Posted on Apr 11, 2008
Canon S2 IS says memory card error"card locked" how do I unlock it?
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 21, 2013 | Canon PowerShot S2 IS Digital Camera
Can I use a 4gb sd hc memory card in a canon powershot s2 1s? the screen says there's a memory card error
The Max. Memory Size of ur camera is : 2048Mb/2GB.........That is reason for which it says that there is a memory card error.
Feb 17, 2011 | Canon PowerShot S2 IS Digital Camera
I have a 4GB SD HC card that works well in my Powerhot SD750 but gives an error code "Memory Card Error" and "Card Locked!" on my PowerShot S2 IS. Is there a fix for this? Peter
The S2 IS uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. While you can use SDHC cards with the SD750, you will have to use SD cards, 2GB and smaller, with the S2 IS.
Oct 21, 2010 | Canon PowerShot S2 IS Digital Camera
Card reader always says memory card error
This camera will not accept high capacity mem cards. You are limited to the 2GB size, but that is not much of a limitation since this 5 megapixel camera can be set to put more than 2,000 pictures on a 2GB chip.
Perhaps I am not understanding your question. Are you talking about the camera giving a "memory card error" message or some other device?
Aug 10, 2010 | Canon PowerShot S2 IS Digital Camera
Getting memory card error
Some cameras require a new Firmware update of it's internal brain so it can recognize larger capacity memory cards. Check out your cameras website, look up the FAQ column or support and see which memory card sizes are compatible.... Good luck
Dec 26, 2008 | Canon PowerShot S2 IS Digital Camera
Menory card error
The problem is that you've probably got a SDHC (High Capacity) card which is not supported with the S2; it only supports SD cards (up tp 2G)
Dec 24, 2008 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 Is
I just fixed mine. Put your memory card into your computer. Right click on it. Choose format. Reformat the memory card. You WILL lose all pictures stored on it.
Before putting the memory card into your camera, do the following.
Go to MENU and choose RESET ALL.
Choose reset to original settings.
When camera is done doing so, turn camera off.
Reinsert memory card after it is done being formated in your pc.
Then your camera and memory card should work great again. I just did it on my Canon Powershot A620.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
