Question about Acer Aspire 3680 Laptop
S-Video connector I am trying to access a remote DVD burner using my s-video connector, but it doesent work. How can I enable the s-video port? Thankyou
I'm trying to connect my acer 5720 to my tv with an s-cable, please help I have audio, but no video.
Posted on Apr 16, 2008
Take out vista basic pit ib xppro will i workt
Posted on Apr 13, 2008
I require a link to download the software for a Panasonic NV-GS25 video camera to be able to transfer from tape to DVD/PC
As you may know, the Panasonic website has only the update files for the MotionDV Studio LE software that came with the camcorder. However, this DV camcorder has a Firewire connector. You just need ANY video editing software, the right Firewire cable (4 or 6 pin, or 4+6 pin cable), and a Firewire port (add a card to your computer , if it doesn't already have Firewire, aka IEEE 1394A).
  • Apparently, Vista and Win7 on many newer PC's come with something like Movie Maker. Mac OS X has iMovie. Both support Firewire devices.
  • DVD burners and computers with DVD burners usually come with some kind of burner software. Sometimes, they have a basic (Lite) video editing package - examples include Nero, Roxio, and Ulead. Even at the "Lite Edition" level, these video editing packages work with Firewire camcorders.
Feb 23, 2011 | Cameras
Tip
DVD Player Quick Connect Tips
There has been a lot of confusion lately about how best to connect your new DVD or Blueray player to your TV set. For many this has been a nightmare since the introduction of the new Component and HDMI versions of Higher Priced DVD and Blueray disc players.
Remember that your new Blueray player will play DVD's as well as Blueray Disc format movies.
For the common connection that most people use, there are only 3 wires to consider. Yellow for Video, Red and White for Stereo. Always use the line out jacks on the back of the player to connect to the TV. Use the Line in (Video In) jacks on the TV set.
The only thing to remember here is to match the colors exactly and select the video source from your TV remote control. If all those numbers and buttons are confusing to you, just memorize where your Source button is on the remote, and choose one input at a time until your DVD welcome screen appears.
The next higher quality Video source will be the component Video outputs on your DVD or BlueRay player. These will be Red, Green And Blue.
Also note that you will need a red/white audio cable for sound with these connections since the component outputs only transmit Video.
You will be able to see the audio connectors close to the red blue and green component outputs on most players. All connectors on your player will be outputs, unless you bought a DVD recorder and player.
We will reference only the player type at this time.
As mentioned before, you only need to match the wires from the DVD or BlueRay output to the exact input connectors on your TV, but now the audio connectors need to be used as well.
Component to component cables/
Stereo Audio Cables/
Use your source selector on the remote as before to View your movie.
The easiest connector to hit the market so far is the HDMI version, which combines the Video signal as well as the audio signal into a single manageable cable. If your TV set doesn't have this connector you will need to use one of the above methods to connect your system.
To use the HDMI you need only plug it in to the connector designed for its use on both the TV as well as the player.
There is very little chance you will connect this to the wrong port, but just in case your HDMI TV and DVD/Blueray player are equipped with an Optional USB port, you should read the panel closely to be sure you have the right port. Remember, these connectors should never be forced on. If they are too tight to connect, you may have chosen the USB port by mistake.
Thats my Tip o the Day
Please Vote for this Tip if you found it helpful.
Bob S.
on Mar 23, 2010 | Audio Players & Recorders
What is a USB tv box and what does it do?
This is Teac's description of what this unit can do.
TEAC's TV Tuner enables video and regular Television viewing on a notebook or desktop PC. Simply, turn your notebook PC into a portable TV! TEAC's USB TV Tuner is the smallest video capture USB2 device available today. The tuner allows you to watch, capture, and record your favorite TV/CATV, VCR, DVD or Video Camcorder on your PC, then burn them to VCD, SVCD or DVD disc with your CD or DVD Burner. Simply connect your analog cable or antenna to TEAC's TV Tuner, grab the remote and you are all set! The Tuner can be used to record video files or TV programs in DVD quality. With the bundled MPEG-1/MPEG-2 Encode software, recording a favorite video or TV program can be easily done. MPEG editor can be used to edit video files, which can then be burned into VCD, SVCD, DVD by using CD/DVD Maker software. The Tuner can support multiple video inputs, including S-Video, Composite Video, Coaxial/Antenna TV connector. It is a DVD quality TV/Video recorder.
Dec 08, 2009 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Gear Head Lightscribe 24x DVD+/-R Triple Format SATA
Your original CDROM drive is likely an IDE interface (large rectangular connector), where as the new one is a SATA interface (small narrow connector). If your original is an IDE, the simplest solution is to return the SATA and purchase an IDE DVD.
Oct 26, 2009 | Gear Head 8XDVDEXT DVD External Slim...
My dvd drive is not video files but it is reading data files
What OS are you using?
In windows go to the Control Panel+ Performance Maintance+System(system properties) + Hardware+ Device Manager from the list select disk drive and select the one that you are trying to access and on the general tab make sure that the drive is enabled.
NEXT In my computer right click on the drive and properties make sure auto play is selected for music. And then also if you have more than one CD/DVD drive you it can possible that the drive is set not to play video and music. The too you will find in the properties menu.
Thank You good luck
Aug 27, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
Sony WEGA
If your remote has a wega gate button press that and it will allow you to add and edit the inputs.
Apr 17, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
S-video connector
Usually through the FN + F? key to toggle internal external or both
Apr 14, 2008 | Acer Aspire 3680 Laptop
DVD burning
It's not a DVD burner, it's a dvd player and a cd burner.
Apr 10, 2008 | Acer Aspire 3680 Laptop
DVD burn
Chances are that your laptop has a CD burner and a DVD rom which only reads DVD's but will burn regular CDs
Hope this helps
DVD Burner
Even if the burner is very quick, I suggest that you don't try and use it at it's maximum speed, but the lowest. Try 4x, and if it gives you DVDs that work, then you can start working upwards if 4x is too slow for you, untill you find the fastest speed that gives you working DVDs. Also shut down all other programs while burning, especialy heavy ones. If this is not it, and you keep having problems, add a comment. Good luck!
Jun 20, 2006 | Magic INCDRW4048 MagicSpin (INCDRW4048)...
Acer Aspire 3680 Laptop Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
