Question about Printronix Line Matrix P5005B Printer
Technical assist i can't print ms dos documents from printronix p500n printer
    Problem Solver:
  • 6 Answers
Pl. chack your data cable , and pc port by connecting DMP .to same location.
Posted on May 12, 2008
Up driv short what can i do
Posted on May 09, 2008
Usb device unsupported
We would like to know which usb device is unsupported, please provide more information and we'd be glad to assist you.
For further assistance, please contact Lexmark Technical Support
Aug 25, 2011 | Lexmark T640 Laser Printer
Printronix p5205B
Check to make sure that your ribbon is not folding on the left. Have seen many printers with that ribbon guide off a little causing that issue.
If this is not the case you can try adjusting your platen. If that doesn't work, Shuttle are know to go out. They have coils behind the frets which lose resistance over time. If this is the case the shuttle will need to be replaced.
If you have any questions or need parts or printers please contact me we are an ASR for Printronix. We also offer free technical support.
Rory Cardenas
Midrange Repair and Parts
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
Jul 22, 2009 | Printronix P5205B Matrix Printer
Print from DOS
Try Start --> Programs --> MS DOS
or Start --> Run --> enter CMD
this will take you to a DOS screen
To print a file use the type command and pipe it to LPT1
e.g. type myfile.log > lpt1
Feb 16, 2009 | Compaq Inkjet Ij300 Printer
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
i have problem in winxp for printer proline sereis 5 printronix line printer driver not match
in custom size
so need for printer driver winxp supported
Sep 18, 2008 | Printronix Line Matrix P5005B Printer
Problem in printing in Windows
tell me which model do u have and which Operating Systems you are using..
Apr 10, 2008 | Printronix Refurbished P5212 DOTMATRIX...
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S -P lp text.txt"
Substitute for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
May 30, 2007 | Printronix LaserLine L1524 Printer
Printronix Line Matrix P5005B Printer Logo
54 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
