Toshiba laptop wireless turns itself off so can't connect to a network
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Brand? model?
Drivers for the wifi card?
bios?
Posted on Apr 19, 2008
How to load Integrated Wireless LAN on my toshiba satellite a45-s1202
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop. However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings." This will give you options for modifying how you connect to the Internet. Select "Connect to a Network" or "Show Network Status and Tasks." Both selections will show you whether you are disconnected from the wireless network. Select "Manage Network Connections." This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection. Engage the wireless connection. Turn your wireless switch to "On," then right-click on the wireless network connection. Select "Connect/Disconnect." Wait for the IP address acquisition. It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address. When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength. Launch your favorite browser to access the Internet using the wireless connection.
Feb 03, 2013 | Toshiba Satellite A45-S1202 Notebook
Cannot stay connected on wireless networks. Troubleshooter shows problem detected with wireless network adapter and a cable unplugged. I am running a toshiba satellite L505d with a realtek RTL8187SE...
Hi, Please make sure that you have turned on the wireless switch on your laptop because this is a message that usually appears if the wireless on the laptop is disabled.Also please update the wireless drivers for your laptop from the Toshiba website. Thank you for your time and best wishes for your effort.
Jan 08, 2011 | Toshiba (PA3212U) Wireless Adapter
Wireless adapter in laptop keeps turning itself off and back on
there must be a touch button for Wireless networks put it off ....... guess it is looking for some wireless networks around.
Jul 01, 2010 | Compaq Presario CQ60-220US PC Laptop
Cant connect to a wireless network
You need to turn on your wifi which maybe on the outside or on your keyboard, then go to bottom right of screen & left click on wireless connection then click on "connect to a network"
Apr 24, 2010 | Toshiba Satellite A100-S8111TD Notebook
Where is the wireless switch
Okay the laptop is only pertaining to itself, so depending on the laptop make and model there is a button that has a little tower above the keyboard or a left to right switch somewhere on the chassis. If that is turned on, then make sure the wireless network adapter is enabled in the control panel
Apr 12, 2010 | Toshiba Computers & Internet
I don't know how to use wifi on my Toshiba A45 S120
Feb 11, 2010 | Toshiba Satellite A45-S120 Notebook
Can't connect to the internet...
One tip for you is make sure you are using one software to run your wireless card, either remove the software for the wireless card and let windows configure it, or tell windows you have a excisiting software that will control your card, it sounds like software conflicts one is turning on other is tunring off and so on.
Nov 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Wireless connection
check to make sure the wireless zero configuration utility is on ..check from services in the computer and make sure that there is a check in use windows on the network card itself from network connections. Then it should work .
Jun 13, 2009 | Actiontec GT704WG Wireless Router...
Wireless networks not found
Sometimes Satellites get a little flaky when on battery power. If you haven't already, plug in the power cord with the notebook cold - meaning off for about a minute. Boot the notebook and try to do the setup with the power connected. If that solves it, it should work fine when you switch to battery power. If it doesn't, repost with your results.
Jun 11, 2009 | Toshiba Satellite M65-S821 Notebook
Wireless network undetected and problem with wireless lan
first check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
Nov 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
David Payne
David Payne
