Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite 795.7756
I am getting the er dh code. It sounds like the problem is the controller assembly but how do you replace the controller assembly? Where is it located on the refrigerator?
  • patty52 Apr 12, 2008
    I have the diagram and had it before I asked the question. The problem is that the diagram does not tell you where on the refrigerator all these parts are located. At the Sears parts store I visited, one person said I needed to take the inside back off the machine to get to the part. Someone else said I needed to go through the outside back of the machine. Where are all these parts located in the machine and how do I reach them?
  • Anonymous Mar 12, 2014
    Digital screen says er dh
    President:
  • 1,314 Answers
Http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00002&documentId=50029842&modelNumber=79577549600&productCategoryId=0161000&brandId=0583&modelName=REFRIGERATOR&backToLink=Return+to+Sub+Componentsyou can go here when the site is up enter your model number and click on refridgerator controls section you will see parts look for defrost control get the part number then will be a little square box click on it it says show diagram then check the diagram fo the part number thats the easyist way to tell you if you need more help then reply to me picture is wworth a thousand words
Posted on Apr 12, 2008
I am getting error code dH.. What is this?
Thank you for contacting fixya.com.
DH means defrost heater and refrigerator computer is not sensing the defrost cycle. It is due to a bad defrost sensor located on the evaporator behind the plastic cover in the back of the freezer compartment. You need to replace that.
Also check this link if it helps:-
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 73503 Stainless Steel Bottom...
I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
On the door display it says " ER DH " what does
I found this to be quite up your alley... gives you possibilities for DIY repair.
Apr 13, 2011 | Kenmore Elite 44723SS Commercial...
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
We have a Kenmore Elite Trio that keeps giving us an error message in the electronic window of er dH
Aug 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Error Message ER DH
This is a refrigerator manufactured by LG and is well known for this type of malfunction. There should be two 1/4 inch screws on the outside of the freezer drawer tracks near the front that will allow you to pull out the entire door assembly. Once this is done and the unit is fully defrosted and unplugged, there are a couple/few screws in the back freezer panel. Once the panel is removed, this part is located on the upper right side of the evaperator coils. It is sometimes wedged in tigtly but should pull out with a good tug. Unplug the white harness, remove defective part and reverse this process. Good luck and happy shopping for the shoes.
Aug 25, 2009 | Refrigerators
Er dh code error on Kenmore elite trio
Jul 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Refrigerator error er dh
Sep 21, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
532 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
