HOW DO YOU OPEN A GE WASHING MACHINE - Washing Machines
  • dimpleset Apr 12, 2008
    great it worked !!
    Genius:
  • 1,073 Answers
If it is a reletivly new machine then yu need to remove the frount panel to get in to the machaine for repairs.
take a putty knife and between the frount panel and the top panel and insert the putty knife into the holding clip 4 inches in on each side as you feel the spring action of these clips pull forward on the froun panel, repeat for the other side the same way and the frount will be off
Posted on Apr 11, 2008
Not geting the cold water. Only once and a while even though set on Bright colors
Fixing a Washing Machine with Slow or No Cold Water Fill ...
? 7:40
www.youtube.com/watch?v=c5r49nuMjao
Feb 10, 2014 - Uploaded by SamuraiRepairman On washers with this problem that do the rinse cycle with coldwater only, the ... Top comments .... It's a front loading machine so I can't open it when it's on. .... GE Washing Machine Repair - Water Overfills, Overflows Washer ...
Aug 09, 2015 | GE WHSE5240D Top Load Washer
GE Washer wds2080d8ww will not adjatate
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Nov 22, 2011 | GE Washing Machines
The door will not open. Says door unlocked but won"t open
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Feb 11, 2011 | GE WSXH208A Front Load Washer
GE Washer wont drain. Wont agitate, does nothing. Washer is part of a stackable unit about 4-5 yrs old. Checked circuit breakers and electrical and water supply. What should I check? Are there fuses inside...
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Here is a link to the part you need.
Jan 10, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
When the installer tested my newly purchased GE Profile washing machine, I saw him test the incoming water temperature with the lid open. How did he defeat the lid switch?
Hi, open lid , look carefully there's a slot where you can activate switch, use something none metalic, like pen and press to activate.
Aug 02, 2009 | GE Profile WPRE6150KWT Colossal Capacity...
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
GE topload washing maching won't spin or agitate. Where is the reset button
Here's what the GE technician just did at our house to reset the electronics:
Unplug the machine for at least 30 seconds.
Plug it back in, then open and close the lid six times.
That fixed my problem. Good luck with yours.
Dec 06, 2008 | GE WBSR3140DW Top Load Washer
GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Mar 24, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
