Question about Nintendo DS Lite Console
Nintendo ds lite
Message on the screen reads error: open xmenu.dat error
when trying to load games on to the ncard we may have deleted start up menus is this possible ? if so what is the solution
thanks
  • 2 more comments
  • jag5y Apr 12, 2008
    what is the mk5??
    i still have the error message when i switch on the ds lite
    Open xmenu.dat error!
    When i go into usb mode it comes up with
    usb disk v1.45(16g)
    how do i fix this?? HELP PLEASE
    the site address you gave me has no information relating to this problem any other ideas please
  • jag5y Apr 13, 2008
    there is nothing on the site you recommend to help me
  • 818 Answers
  • 3,037 Answers
Get the latest menu that includes the latest x-menu
follow these steps:
format the mk5
transfer all files from the download to the root of the mk5(copy the whole ds system folder to the root, let those files stay in the sytem folder, it's directly in the mk5, not in any subfolders. the same place where you put the games and the saves)
Now reboot and it should work.
while transferring the menu fioles it's nice to also upload the latest savetype file
Posted on Apr 12, 2008
  • 4 more comments
  • Benjamin Patri
    Benjamin Patri Apr 12, 2008
    you can download the latest upgrade from here
    http://gbatemp.net/index.php?dlcategory=...
  • Benjamin Patri
    Here are a little better instructions to help you out
    All I can say is it worked fine for me. The instructions are simple to follow.
    Neos instuctions:
    1. Use MK5 USB Linker connect PC , and enter USB data exchange mode , PC will detect one removable disk (MK5) have inserted
    2. Copy "MK5_Menu_V1.39_AUTO_Upgrade.nds" to MK5
    3. Restart NDS, enter MK5 menu, choose "MK5_Menu_V1.39_AUTO_Upgrade.nds" and run it,and restart NDS.
    4. When NDS power on, hold L+R+A+B+DOWN to fast format whole MK5, or you can use A+B+START+SELECT+UP to make a low-level format ,then copy all data (include folder) from this uncompressed file.
    5. Now new system is ready ,restart NDS and enjoy it!
    My slightly expanded changes to the instructions:
    2. Copy "MK5_Menu_V1.45_AUTO_Upgrade.nds" to MK5
    3. Remove MK5 USB Linker and restart NDS, enter MK5 menu, choose "MK5_Menu_V1.45_AUTO_Upgrade.nds" and run it.
    4. Restart NDS. When NDS power on, hold L+R+A+B+DOWN to fast format whole MK5, or you can use A+B+START+SELECT+UP to make a low-level format. Note: Low-Level Format takes a long time!
    5. Use MK5 USB Linker connect to PC. Restart NDS. Enter USB data exchange mode. Then copy the following files from this uncompressed .rar file to your MK5:
    DSYSTEM (entire folder & contents)
    MK5_2Mbit_test_V5.nds
    MK5_PassMe.nds
    xmenu.dat
    6. Now new system is ready ,restart NDS and enjoy it!
  • Benjamin Patri
    you can get the mk5 menu from here too.
    http://www.neoflash.com/download/MK5_Men...
  • Benjamin Patri
    you followed both of my instrutions exactly and neither one worked?
  • Benjamin Patri
    look at this link, it is about people with the same problem and how to fix it
    http://www.neoflash.com/forum/index.php?...
  • Benjamin Patri
    Benjamin Patri Apr 13, 2008
    So you are saying that none of the above that I posted fixed your problem? You followed all of the steps?
    Genius:
  • 3,422 Answers
HI,
That's a firecard error i'll let you know if there is any solution to fix this problem.
  • 2 more comments
  • Priya darshan Apr 12, 2008
    HI again,
    So here is a solution.
    When you put it into USB mode and accessed it on your computer, you
    must have opened the xmenu.dat file. For some reason, this corrupts the
    card (there is no problem unless you open that file) all you need to
    do, is format the card and then put on the xmenu.dat file again.
    Goodluck,
    Please don't forget to rate the solution.
    All the files you need are at www.neoflash.com.
    Your need (MK5) v1.45 which is in the download section.
    Some of the nds roms do needed unraring before putting on memory card. They should be in .nds format etc.
    The files you need are...
    DSYSTEM (Entire Folder And Contents
    MK5_2Mbit_test_v5.nds
    MK5_PassMe.nds
    xmenu.dat
    When you have these files THEN you can format by...
    Please insert both cards in to the DS and power up, tap the screen to continue as you would for any normal game.
    You will then come to the menu "USB Mode" and "Menu Mode"
    Instead of selecting one please press and hold the "select button" on the DS then tap "start"
    Select "Quick Format"
    Once complete restart the DS, you will have to tap the screen as above and this time select" USB MODE"
    By formatting the menu file will have been deleted from internal
    Memory and will need replacing with the files. downloaded from
    neoflash.com
    (MK5) v1.45
    MK5_PassMe.nds
    xmenu.dat
    (Drag and drop these files only)
    Now your new system is ready, restart NDS and enjoy
    Will fix almost all problems with DS Firecard and applies to both 8 and 16gbit.
    download xmenu here (scroll down half the page)
    http://www.logictoys.co.uk/vmchk/Nintendo-DS/System-Enhancements/DS-Fire-Card-8Gbit.html
    after that, restart the nds and if you have a screen that says something like need udisk version 1.45, you can download it here
    Http://www.dsgba.com/down/nand_stable_26...
  • 19,396 Answers
Disconnect from power plug and remove battery. Put back all together. try this first
    President:
  • 1,944 Answers
Did you try resetting th unit?
  • Damen Wong
    Damen Wong Apr 12, 2008
    Does the card have the latest firmware?
    Also, did you put the dat file in the root?
  • Damen Wong
    The last two things I wrote should fix the error.
Well when i put when i put my ncard in and turn on the ds it is just a blank screen saying error: xmenu.dat
Probably the xmenu.dat is deleted. Best way is to copy all the games (.nds files) and the log files (.sav files) to your computer, reformat the card and copy back the games from your pc to your card.
Don't forget to rate
Jan 06, 2009 | Nintendo DS Lite Console
Error open xmenu dat error
when you put ncard it just says xmeu error
After Xmenu.dat
okay, i know an easy solution to this
email me and i will give you step by step instructions, you will need to format your Ncard through your DS manually , i know it sucks but it happens, i will also send you the appropriate files so you wont have to mess around with the update, my email is
jackdye@yahoo.co.uk
Dec 18, 2008 | Video Game Consoles & Games
Xmenu.dat error
Hi there
your not supposed to open it as its a dat file, all you have to do is drag and drop it into the Ncard, thats all there is to it, any other questions or help you need, email me
jackdye@yahoo.co.uk
i hope all goes well in the future.
Dec 17, 2008 | Video Game Consoles & Games
eso es que no tienes el archivo xmeno.dat, lo se porque eso mismo me pasa a mi y no lo encuentro paradescargarmelo.
Aug 02, 2008 | Nintendo DS Lite Console
Error:open xmenu.dat error!
watch this guys video to see what you have to do http://www.fixya.com/support/t636896-ar_broken
Jun 21, 2008 | Nintendo DS Lite Console
Nintendo ds ncard
i think you would need the xmenu program, email me and i will send you one jackdye@yahoo.co.uk im here to help and thats what i will do
Jack
Apr 24, 2008 | Nintendo DS Lite Console
Nintendo ds lite problem game
It may be because the game is from Tenerife and the nintendo is from a different country? Love Tamsin!xxxx
Mar 09, 2008 | Nintendo DS Lite Console
Nintendo dslite ncard
I did have Error: Data is not align 16k! when i start up my ds.
What I did was..
MK5_PassMe.nds
xmenu.dat
By formatting the menu file will have been deleted from internal Memory and will need replacing with the files. downloaded from neoflash.com
(MK5) v1.45
MK5_PassMe.nds
xmenu.dat
Jan 29, 2008 | Nintendo DS Lite Console
N card
listen,i'm confused on your question.but i'll still help.don't turn off your ds on and off.that may shorten the life,which means you'll spend more time charging then playing,also don't take out your game card while your ds is on.save your game,go to the main menu and turn it off.once it is off you can take the card out.if this is not helpful call the nintendo customor support center number 1-800-255-3700.
Dec 30, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
119 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
