Question about Samsung GX-1S Digital Camera
Can't turn on
my camera can't not turn on. i put new batteries in and plug in AC adapter as suggested on this site, but the baterry icon still blinking without full bars and the camera still will not turn on. It was working fine until about a week ago. I am not so sure where to start troubleshoot it or even if the manufacturer can help me with it.
Please help.
Thank you
nrongra@gmail.com
  • 983 Answers
Just follow some tips below:
when u insert battery and turn on you told the battery icon will blink so try giving reset once ....
i think the firmware has got corrupted .... you must install the new firmware to it ...
after trying giving the reset option if problem persists then check whether there is connectivity with the pc or not ....
contact the service show room and get install the new firmware for your camera then it will work ....
and before have a check whether it is charging or not when the battery icon blink ...
if there is no charging progress means then there may be problem in the charging port or may be the charging IC is damaged ....
if it is charging then make sure that there is no problem with the charging port if not you must contact the service showroom and you must get replaced the port ...
any doubts reply me
i am always here to assist you
thank you
bye
Posted on Apr 11, 2008
Toshiba satellite c55t wont power on, just blinks once every 4 seconds
check power cord is fully inserted into laptop
if no joy
try also forcing a power down by holding in the power button for 30 seconds and then try power button again to power it up .
might be in hibernate mode !
Dec 04, 2017 | Toshiba Computers & Internet
Sudden discharge of batteries
The icon may indicate the batteries are fully charged and your measurements would indicate this but I suspect the batteries are no good..
Nov 29, 2013 | Cameras
Have a compaq presario running win 7. The system does not recognize when it is running on ac power (original ac adapter). The battery charges but the only sign of this is the battery icon says xx%...
Hi, it seem as if your battery is faulty you should try another battery to see if the computer will recognize when it is charging, you can also try your battery in another compaq presario computer to see if it will have the same problem.
Aug 02, 2010 | Computers & Internet
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
Toshiba Satellite A55-S306
Sounds like you have snapped the centre connector in the laptop. If you look at the AC connector on the laptop there should b a "pin" in the centre. These frequently snap off, symtoms are :
Battery will not charge
Will not turn on from AC supply.
There are some firm which will replace the ac jack for you but it will cost.
Interent search .. replace DC jack on toshiba
Sep 05, 2008 | Toshiba Satellite A55-S306 Notebook
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
Won't go on
Hey ghgyu,
I would first make sure you have the batteries installed correctly. If you are using a camera dock or you have an AC adapter cord I would try removing the batteries and try turning the camera on while connected to the camera dock or plugged into an outlet with the AC adapter cord. If the camera works this way I would then try cleaning the battery contacts with a soft cloth or an eraser. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 09, 2008 | Kodak EasyShare DX6440 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Won't turn on
Ouch! You can't use an AC adapter with any battery-operated equipment you choose to just because the plug fits physically. The A70 requires 5-6 volts, and a Pavilion adapter typically puts out 18 volts. You most probably blew out your Canon's power supply within a few seconds, unless it's fused somehow. Next stop: tech support/repair shop/camera cemetery. Sorry.
Aug 23, 2006 | Canon PowerShot A70 Digital Camera
Samsung GX-1S Digital Camera Logo
103 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
