Question about GPS
I have a tomtom one origional. i got a new sd mem card for it but the tom tom wont recodnise it
  • REDBIKEMIKE Jun 14, 2008
    My Zumo 550 will not recognize a new sd card ''sandisk'' 2 gig's.I have downloaded music to the card but the Zumo will not play it. Any thoughts...
  • 515 Answers
Check that the sd card is compatible with your device:
http://www.tomtom.com/support/index.php?Language=1&query=sd+card&FID=2634
Some sd card brands doesnt "speak well" with TT products.
If possible, try another brand.
I have good experience with Sandisk cards...
Posted on Apr 11, 2008
TRIED TO UPDATE MY TOMTOM GO 710 BUT NOT ENOUGH MEMORY BOUGHT NEW CARD BUT TOM TOM WONT TAKE IT TRANSFERED DATA BACK ON TO OLD CARD BUT TOMTOM WONT TAKE THIS...SHOW TWO CROSSED HAND ON MEMORY CARD...
Just had the same problem..............
I discovered that you must only use an SD card and not an SDHD card.
I bought a bigger SD card (2Gig), installed it and copied the data I wanted without any probs. With the SDHD card I couldn't transfer anything and didn't get any help as to why...(there's a lot to be said for trial & error).
Hope this helps
Jun 09, 2011 | Tomtom GO 710 Car GPS Receiver
My tomtom wont disconect from the computer just gives me a red x
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH (TOMTOM HOME) if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Jan 13, 2010 | Tomtom ONE GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Tom tom wont work after connecting to the computer
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work
Sep 17, 2009 | Tomtom One XL GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
Tom tom sd card wiped clean
more than likely, I just purchased a new tomtom sd card on ebay with all the new maps on it, ver.7 got it for a UK seller no problems, did you back it up on your computer? hopfully you did, then you can just connect it to tomtom home and reinstall it.
Oct 11, 2008 | Tomtom GO 300 GPS Receiver
Tom Tom XL
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
May 05, 2008 | Tomtom One XL GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
GPS Logo
44 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
