Question about Sony Cyber-shot DSC-W80 Digital Camera
DSC-W80 zoom extends, shutter opens, closes, zoom closes, 5x, won't work
When the power is turned on the zoom extends, shutter opens, closes and zoom withdraws, this happens 5 times before a read out on the screen telling to turn the camera off and on, but upon doing that - the process starts again. The camera will not funtion.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey kbcinc,
I would try taking the battery out and waiting a minute and then reinserting the battery. Another option you have is to try and reinitialize the camera, but you would need access to the settings menu on the camera and it doesen't sound like you do. To initialize the camera go to main settings 1 and choose initialize. If this doesn't work I would bring it to an authorized service center to have it looked at.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Apr 24, 2008
My camera stopped working suddenly. When I turn
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jun 01, 2010 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Issue with my Sony Cyber-shot DCS-W80
Hi!
Does the display itself or just the image blink? Actually, W80, W85 and W90 has a problem with the shutter cable connector - it looses contact from time to time, so the shutter could open or close all the time, changing the amount of light getting through and when shooting doesn't close as the camera is not able to control them normaly as there's a loose connection. If the pictures have horizontal lines (zoom in the picture to check it) then it's 100% this problem. If so, you should contact your local Sony service center and see if they can fix it for free as it's a factory problem. If they don't aggree / ask too much, you can contact me at toms.safranovs@gmail.com and I can try to help you to fix this problem yourself (if you're ready to open it).
I work in a Sony service center.
Hope this helps!
Tom
Jul 30, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Using digital camera as a webcam
I want use to my sony dsc w80 camera to web com but I dont know please tell me
Apr 03, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lens cover opens only a **** on Sony DSC-W80
Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in Part Store
Install new barrier block as shown following image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
Feb 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Opening and closing 3 times and then saying turn off and then back on
So 2 weeks ago my Sony DSC-W80 stopped working. Our friends dog ran into the camera (in my girlfriends hand) full speed. It started opening and closing a few times, and then giving the "turn the camera off and back on" message. I read about tapping around the lens, etc. None of this worked.
I took off the camera body and carefully examined the interior of the camera. Turning in on and watching closely, I discovered the problem. Looking at the camera from the front, I saw a slider on the top right side of the lens that appeared to be jammed. I then saw a spring that was attached to the slider and free on the other end. Apparently when the dog rammed the camera, the other mount for the spring broke off (they are very fragile). The purpose of the slider is to adjust the viewfinder based on the zoom range of the lens. I simply removed the slider which had jammed when the spring came loose. Camera works flawlessly now. The only issue is that the viewfinder doesn't zoom, but who uses the viewfinder anymore anyway? Oh, and I have a screw leftover. What project isn't complete without having extra parts when you are done?
Hope this can help someone else!
Sep 29, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
DSC W80 - Turn the power off and on again
Hi every one i have Sony CyberShot DSC-P41 and it was display the same Message i read that this message means the lens mecanism get stock so i shake the camera but nothing happens but when i getting prepared to un-assembly the camera it fall down out of my hands and wen i take it again it was fix, so you just have to hit or shake the camera a little bit hard.
Mar 03, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Dsc-w80
remove the battery and press and hold the power button for a min. then reinsert the battery and turn the power back on and then try to change the language again.
please post me a message if it worked
avaya ****
maimai alovera
Jan 30, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
75 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
