Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Clock display board
My original clock display progessively got dimmer and dimmer and is now dark. All the features of the oven that we use (burners, bake) still work. I even get a 'ding' sound when the temp reaches the inputted value (say 350 degrees). I decided to replace the clock display (71001799) and that appears to have done the trick. I now have the display back! BUT after a few minutes I get an F1 error code and the oven beeps continuously. I've turned off the power again and even cleaned the ribbon cable and made sure all the contacts were snug. When I put the old clock display unit back in I do not get any error codes or beeping. I read where the F1 means a bad power relay board in the back of the unit, another costly item :( Could my new clock display unit be defective?
  • 4 more comments
  • fm2359 Jun 27, 2008
    after a power outage the clock display is very dim
  • Merry44 Jul 08, 2008
    My oven is about 7 years old. Yesterday the numbers on the touch pad started to dim. The oven still worked but I couldn't see the temp or the time. We set the timer just to see if it worked and it chimed, but no numbers showed. Today the pad is completely dark.
  • Thom Cotruvo Nov 23, 2008
    I have the same problem. Where can you buy a C3 capacitor? On the internet? How do I specify the correct one?
  • susan533 Feb 04, 2009
    i heard or saw a "pop" on the elec range display panel and it went dark. Oven temp and timer still operate and beep as they should. I cannot read any time or temperature. my range was installed in 1997. SVE47600B.
    how do i replace the "capacitor C3" element referred to in other people's problem notes and is my range going to work with that C3 or is it too old?
  • dg4323 May 03, 2009
    The clock on my Jenn-air sce30600 slowly stopped working and now it is totally out. all of the controls still work fine but I would like to repair it. Can you give me the part number and instructions on how to replace it?
    Thanks,
    Dan
    I have the same problem with the display going out. Can someone give me the part number and where I can find the instructions on replacing it?
    Dan
Replacing capacitor C3 on the clock board will correct the dimming problem. I will cost you about $2 for the part. Replacing the board does the same thing just with a higher price tag. Unfortunately, tt sounds like you may have a bad "new" board if this problem happened as soon as you put it in.
When I had the dim display problem with mine, the oven still heated up, chimed at temp, etc -- you just couldn't see the numbers. My wife didn't like it, so I fixed it. If your old board works like mine did even though the display is dark, you could try replacing the noted capacitor and see what happens.
I hope this helps.
Posted on Apr 13, 2008
I have a frigidaire m/n PLES389ECD and the burners and oven aren't working and had the error code f20, the clock timer was replaced but now the clock is the only thing working the burners and oven still...
The ESEC system and the electronic oven control ain't communicating. Check the wiring connections between the oven control and the esec controls. The thang is designed to lockout the top burners while the self clean feature is in use. If you failed to reconnect that connection which feeds back to the ESEC I imagine nothing does work. LOL. here's a video which shows how it works and I have the manual loaded on Gdocs fo you.
30 Inch Freestanding Electric Ranges_Rev A (5995438461).pdf (4 megs) printable.
Dec 31, 2010 | Frigidaire Ovens
I have power to the burners on top but the oven dont work an the time clock is blank
The Electronic Range Control (ERC), also known as an Electronic Oven Control (EOC), controls all the features of the oven. This is your clock/timer assembly. The surface burners work indepently of the oven and usually have electrode type igniters that get their power from a spark module. Since you mentioned your clock display is blank, more than likely you have a defective ERC board. The following link explains how to replace one:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
A replacement control board can be purchased from any of the following webistes:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: In most cases the overlay (preprinted plastic display covering with all the numbering and letering on it) does NOT come with the control board. If your overlay is still in good condition, it can be easily removed from the old control board and reapplied to the new one. Just make sure you properly orient the overlay so the buttons all match up. If you need to replace your overlay, you may need to order it separately. Read the part descriptions carfeully to see what your replacement parts include.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Aug 17, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The burners work but the clock does not light up and the oven won't work either
It sounds like your Electronic Oven Control (EOC) board is defective. This is the clock/timer assembly on the operator console. The EOC controls all the features for your oven, but the surface burners work independently. So, if the surface burners still work, the oven does not and the display is not present, its time to replace the EOC. The following link explains how:
Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The EOC will be listed under the "Control Panel" parts section as item 2. The price and part number will depend upon the last three digits of the model number.
If you have questions please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Aug 05, 2010 | Maytag MER5750 Electric Kitchen Range
Range
Unfortunately this usually means the Clock/Timer assembly needs to replaced. The Clock/Timer controls all the features of the oven, while the surface burners are controlled by each individual infinite switch on the control panel. Thats why your surface burners will still work, but the oven does not. That fact that there is no display also is a symptom the board is defective. They boards do not have a fuse and are not servicebale. It needs to be replaced. This is not a difficult repair and can easily be repalced by the average do-it-yoursefler. The following link epxlains how:
The part number for a replacement circuit board is 316207522. The overlay (the plastic preprinted template that is applied to the board) is sold separately (part number 316220804). If the current overlay is still in good shape, it can be peeled off and reused.
You can purchase replacement parts at any of the following websites:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing. So, shop and compare.
NOTE: The Sears website sells a refurbished version of the control board for much less than the other sites. The part number is 316207502R.
If you have any questions about this repair, please let me know. I hope this helps you.
Jan 06, 2010 | Frigidaire FEF352 Electric Kitchen Range
Frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Nov 16, 2009 | Frigidaire PLEF398C Kitchen Range
The touch pad on my Jenn Air Model JES9800BAF does not work. The clock does not display either. All four burners operate normally.
All burners work fine, clock display is blank, if the oven isn't working either, your display / control board is shorted out
Nov 13, 2009 | Jenn-Air JES9800BA Electric Range
Display too dim to see
I purchased a new clock module off the internet to try.
Mar 22, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
GE oven
try turning off the power to your oven and turning it back on. if that doesnt work then you are going to need a new control board.
Feb 08, 2007 | GE Spacemaker JMP28 Electric Kitchen Range
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
591 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
