Question about 2wire (1000-400108-001) Router
Connecting 2wire router with desktop pc and laptop
I have a laptop connected to 2wire router throught the ethernet cable and my desktop pc connected with a wireless adapter. I can't get on the internet on my laptop at the same time I have the desktop connected to the network. Can I connect the two with this router? Before I got the wireless connection running I could access internet through laptop with ethernet cable, but now I can't connect at all.
Please help
  • Anonymous Jan 25, 2009
    laptop wont let me access the internet
    Scholar:
  • 53 Answers
Hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Posted on Apr 14, 2008
  • 323 Answers
You will need to check your router settings and verify that the wireless settings are setup.
To access your router go to http://192.168.1.1
You may need to consult your routers website and check for configuration with the wireless part of it.
If you can get me the model of your router I can direct you further.
Let me know if you need any further help =)
Posted on Apr 11, 2008
Att 2wire 486 router, why does ethernet light go off when widows boots on, wireless works fine?
Are you connected by a cable to the desktop, if so try another cable.Is your ethernet adapter enabled and working properly on the desktop?
Oct 12, 2012 | Computers & Internet
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Oct 10, 2010 | 2wire (1000-000057-000) Modem
I have a 2wire 2701hg-b router....I can connect to the internt through wifi on my laptop but when I try to connect through ethernet on my desktop it says it accuirring signal. I tried to reinstall the...
First look in device manager and verify that the network adapter is enabled, if so you can try disabling it then shut down and reboot the PC.
Once booted, go back into device manager and enable the network adapter.
Run the software that came with your router and follow the steps provided.
Make sure your network cable from your router is NOT connected untill instructed to do so.
You will need to have the network cable from your modem connected to your PC for the router software to detect network connection.
Good luck, I hope this helps.
Have a nice day.
Jun 01, 2010 | Computers & Internet
Cable and wireless question
Not possible, since the "input" to the 2WIRE modem is a 4-wire telephone-line, not an 8-wire Ethernet cable.
Instead, spend about $40 to buy a D-Link Wireless G modem, and connect its WAN port to the cable-modem, and connect up to 4 Ethernet cables to "wired" computers, and configure the "wireless" component of the D-Link router.
May 07, 2010 | Computers & Internet
How do i hardwire my desktop to 2wire
Behind the 2Wire you will find ports like LAN or Ethernet
Connect RJ45 cable between your 2Wire and the back panel of the computer tower (ethernet port)
Jan 13, 2010 | 2wire (1000-400108-001) Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I get the WEP key for my 2wire 2700hg-b router?
Take a look under your 2wire modem, wep key is located on the bar code.
Apr 09, 2009 | 2wire 2700HG-B Router (2700HGB)
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
2wire (1000-400108-001) Router Logo
1,825 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
