Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I don't know when this happened, but the input for the coax cable from the antenna/cable got broken off right at the base of it where it comes out of the what I'm guessing is the RF adapter. My question is can you replace just the adapter (part #) or do you have to replace the entire circuit board (part #). Any info would be greatly appreciated. Also, part numbers for either of these parts would be greatly appreciated as well.
  • deereagtech Apr 12, 2008
    Yes, that is the correct model.
  • RCA Master
  • 13,433 Answers
Hey, Im pretty sure the it can be soldered back in or replaced with another.
or if the damage is extensive then the whole board might need to be replaced hard to say from here.
Id need to find the service manual to get the part numbers. Il look but i think they cost.
Posted on Apr 11, 2008
  • 1 more comment
  • Ekse Apr 11, 2008
    and your tv is
    RCA > D52W20
    Is that correct?
  • Ekse Apr 12, 2008
    il get back to you soon.
  • Ekse Apr 12, 2008
    the rca service manuals arent free, I cant get you one.
    Id suggest you contact rca and ask if they can sell you one.
    RCA Contact Information
    Main support number 580-634-0151
How do i get my Dynex TV to work on an antenna
Easy. First put up a good outside or wall antenna. Then run a coax cable (not flat lead wire) from the antenna to the tv. To do this you need to get a "balum" to go from the antenna to the coax wire. It's a small plastic 'transformer' (( about the size of your pinky finger)). The other end of the coax wire should have an 'F' connector put on it so it can screw into the F connection on the back of the tv set. Then get your remote and go to the input of your tv and change it to antenna input. Then do a channel scan. Let it finish scanning and it will let you know how many channels it picked up. If you're in a big city then you may pick up as many as 100 or more channels. If you're in the country, you may only pick up about 5 channels! If you need more channels then go back to Home Depot or Lowes and get an 'antenna amplifier'. Hopefully one that has about 25db gain. Most only have about 10db gain but the higher the number the better. It should be put inline between the tv and the antenna so you'll need another coax cable for the amplifier to the tv. The wire that comes from the antenna goes directly to the 'input' of the amplifier. Then from the 'output' of it to the tv. You'll love it once it's done and it's cheaper than cable or any other paid service!
Aug 17, 2017 | Dynex Televison & Video
Coax cable does not go in fm antenna connection of RT2781
If the coax cable and the antenna input are "F" connectors, they should fit although the fit may be tight.
Feb 05, 2017 | Audio Players & Recorders
How do I hook up an antenna to the tv? There is no antenna in coax connection. Do I need a converter box too?
there HAS to be a coax connection,unless it is broken off,in that case you need to replace the control board you wont be able to use an antena without it,if using cable box,use hdmi input
Jul 16, 2015 | Televison & Video
Hello.... and H-E-L-P please ! 11 month old Samsung ua60f8000 connected via coax to antenna, suddenly "no signal".... have reset, retuned (now no channels) and tried all except a new coax (waiting for
It is possible that the cable to your antenna is broken somewhere. You have the right idea to start there.
It is also possible that your TV is looking at CABLE instead of AIR, or visa versa.
Nov 15, 2014 | Televison & Video
2008 Malibu LTZ 3.6 engine. Diagnostic code B2470 that is an ONStar antenna issue , and P70496 I called Chevrolet Dealer, But these People have lost their minds with the prices they Quoted . ! I need to...
P70496 This is not a code . Has nothing to do with emission's .Now P0496 does P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
Purge solenoid is probably bad .
Automotive Evaporative Emissions Part One
Cellular Phone Antenna Circuit Malfunction
DTC B2470
DTC B2470 04: Cellular Phone Antenna Circuit Malfunction Open Circuit
The cellular antenna is connected to the communication interface module (CIM) with a RG-58 coax cable. The CIM polls the data from the cellular antenna once every second.
Circuit/System Testing
Ignition OFF, disconnect the cellular antenna coax from the CIM module and the cellular antenna.
Ignition ON, test for less than 1 volt between the antenna coax center terminal and ground.
? If greater than the specified range, replace the antenna coax.
Ignition ON, test for less than 1 volt between the antenna coax outer shield and ground.
Test for infinite resistance between the antenna coax center terminal and ground.
? If less than the specified value, replace the antenna coax
Test for infinite resistance between the antenna coax outer shield and ground.
Test for less than 5 ohms at the cellular antenna coax center terminal from end to end.
? If greater than specified value, replace the cellular antenna coax cable.
Test for less than 5 ohms at the cellular antenna coax outer shield from end to end.
Test for infinite resistance between the antenna coax center terminal and the outer shield.
? If less than specified value, replace the cellular antenna coax cable.
If coax cable tests normal, replace the cellular antenna.
Clear the DTCs and operate the vehicle within the conditions for running the DTC. Verify DTC B2470 does not set.
? If the DTC sets, replace the CIM.
Jan 08, 2018 | Chevrolet Cars & Trucks
I clicked a button by accident last night and now my Vizio tv reads no signal and a small display in the top right corner reads AV. How can I get my tv to read cable signals again??
What input is the cable connected to? (Coax antenna In, component video, composite video)
Look on the remote or the TV itself for a button marked Source or Input. Press this. For some TVs, use the up/down arrows to select the input to which your cable is connected. (TV = coax) On other models, you may need to press the Source button several times to advance between inputs. (I'm assuming you have a remote that works for this feature on the TV; otherwise, use the TV button.)
I hope this helps.
(common modern TV setup: VCR on AV1, DVD player on Component 1, PC to the HDMI/DVI and coax to the antenna in. The source button is needed.)
Apr 26, 2011 | Televison & Video
Bought a Soney KDL-46EX500 last week. Still tring to get it set up. Got the digital local stations programed into it today. (finally) Now I can not figure out how to switch back and forth from locals...
Looking at a diagram of the back of your TV I see that you have only one Coax input. You will need to plug either your antenna or the DirecTV in one of the other sources available on the back of the TV.
According to DirecTV's website, their box also uses composite video cables and depending on the age of that box, may have an HDMI connection also.
Looking at the back of your TV, the composite video cable input is the top two rows to the right of the Coax input you are currently using.
Once you have both connected to different inputs, you can use your remote to switch between the sources and watch whichever you like.
May 03, 2017 | Sony Televison & Video
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
