Red light blinking on power button. won't turn on.
  • 2 more comments
  • puzzled007 Apr 29, 2008
    I have a very similar problem. Power button blinking red and TV won't turn on. If I press power button, the red power light stays on for 5 sec then begins blinking again. Any suggestions??? No information in owner's manual.
  • Anonymous May 08, 2008
    Hi!
    I have the same problem, 4 years TV Sony KV 29 CL11, the red light blinks 11 times.No picture and no sound. i can use neither the PS2.
    thanks for any solution and how much will be cost.
  • jody hunter Dec 16, 2008
    red blinking power button. Tv set won't turn on
  • Steven Willebrords
    Steven Willebrords Mar 12, 2009
    sony kv-28cl11b went dead. After power up the standbye-relay clicks on and then back of again. The red LED blinks 11 times and keaps repeating this.
  • 8,617 Answers
Need to know the model and if it blinks a certain number of times with a pause then blinking again.
Posted on Apr 11, 2008
I have a same problem with my Toshiba TV "theater viewer" its power LED comes on steady and than start to flash at a constant rate. please assist.
Posted on Apr 26, 2008
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Microphone PG58 won't turn on, it has a blinking red light when I push the power button
Your circuit board could be bad, but i would pull out the circuit board and spray contact cleaner onto the button, let it dry a few minutes and connect the battery and press that button quiet a few times and see if that fixes the problem.
Dec 06, 2012 | Shure PG58 Professional Microphone
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
Nov 28, 2010 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
604 people viewed this question
Top Televison & Video Experts
