Refrigerators Logo
A
Anonymous Posted on Jun 10, 2010
Can I stack a Hotpoint Larder Fridge on top of a Hotpoint upright freezer. Both under counter type
Anonymous
Level 3:
  • Master 553 Answers
  • Posted on Jun 10, 2010
Anonymous
Master
Level 3:
Answers
553
Questions
0
Helped
222152
Points
1655
If you have adequate separate ventilation and suffient support for the upper unit it should be OK. You can't just stack one on top of the other or the top one would over hear.
2answers
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
1helpful
The lights are on in the fridge and the control panel works but the fridge or freezer will not get cold. What are we doing wrong? The panel says OF on both the fridge side and the freezer side.
Here are some FAQ provided by Repair Clinic. Click Here=> REFRIGERATOR-TROUBLESHOOTING
For a detailed Refrigerator illustration, click below. Side by Side Freezer on Top Freezer on Bottom Under counter If Iknew what model you have I could answer the OF code. LG has the OFF code that tells you that it is i demo mode but different refrigerators have different codes. See if you can locate the model number in the list below and contact me and I will be able to answer you a lot easier.
Freezers
Washers and Dryers
4helpful
2answers
I need to replace the rubber seal on my Hotpoint ice diamond freezer door I can't find any fixing screws on the inner door panel can I assume then that the panel clips on.
Me too, I have a Hotpoint Iced Diamond Under counter fridge that needs a new seal and i also cant see any fixings to remove it. I did read somewhere that you can't replace them you need to buy a complete new door.
1helpful
The Larder fridge part of my Ariston
sounds like the defrost drain is froze up use hotwater and blowdryer
Jan 29, 2010 • Freezers
Hotpoint larder fridge RL150G keeps freezing at the back fitted n
flap controling tempature not closing to controle tempature 9inside ref
1helpful
Water in bottom of fridge
Probably has ice frozen under freezer tray or drain tube may be blocked by ice diverting water through freezer to fridge vents.
Hotpoint Freezer
Get a hold of CAMCO, they are the authorized parts/repair depot for Hotpoint
Larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Top Silver King Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Silver King Refrigerator Expert? Answer questions, earn points and help others
